Advancing the timing
First of all, what do you consider the "marks lining up"? if youre sure that the timing needs to be that far advanced (the engine continues idling smoother and higher up till the point where the dist. stops) then you will need to pull the distributor out and set it back on the next tooth over. you will probably have to spin the pump shaft with a primer tool (or whatever you can get to fit in there) a small amount so that it will go back into the dist. in its new position. just one tooth over should do ya i would think. good luck.
I rotated the distributor one tooth over and it is idling good now. I am using a vacum gauge as well. I am getting a good constant reading of 19", but about every 5-20 seconds the engine stumbles and the vacum drops off for a couple of seconds. Is the stumble caused by the timing or by something else?
roxndirt64
20
10-07-2008 11:55 PM
sbe12g
04-28-2005 05:07 PM
