ABS Relay Location - Ford Truck Enthusiasts Forums
ABS Relay Location
Old 01-24-2008, 06:43 PM
Blown240 Blown240 is offline
Blown240 is starting off with a positive reputation.
ABS Relay Location
My 00 F150 7700 with 4 wheel ABS has a problem with the ABS pump staying on when the truck is off. If I pull the fuse it turns off. I assume it has a stuck relay, but I dont know what realy it is. Does anyone know the ABS relay location?
Old 01-24-2008, 07:02 PM
antony25 antony25 is offline
antony25 is starting off with a positive reputation.
The relay is built into the module. If the pump continues to run you may need a new module.
Old 01-24-2008, 11:17 PM
Any idea how much new modules are, and are they just electric, or do the brake lines go thru them?
2007 F150 jerky stop in forward Paul Larsen 2004 - 2008 F150 2 09-08-2013 10:18 PM
94 E350 ABS Light On Tenderpaw 1968-2013 Full Size Vans 8 06-10-2013 05:33 PM
01 Expedition ABS Relay? location? Jayhotdaynot 1997-2006 Expedition & Navigator 1 04-07-2010 04:49 PM
Adding a ABS cut off switch to 04 F-250 4X4?? Blue Dog 1999 to 2016 Super Duty 17 01-04-2009 04:49 PM
abs light donald burnash Excursion - King of SUVs 0 09-22-2006 04:41 PM
Tags
03, 1997, 2003, 2007, 95, abs, f150, ford, line, location, locations, module, pump, relay, routing, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
