Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-24-2008, 05:46 PM
lud04X lud04X is offline
Garage is empty, add now
lud04X is starting off with a positive reputation.
Diesel Secret???
I stumbled upon the DSE website that claims with an additive you can use WVO without modifying anything on your diesel.
I have a '95 Powerstorke Diesel and am interested in WVO instead of paying 3.50 a gallon for diesel in WA state.
My buddy runs straight filtered used tranny oil but he's a Powerstroke Diesel mechanic at a local Ford dealership and has access to it. By the way he's run it for two years with no problems in a '95 PS diesel. In winter he starts the truck with diesel and shuts it down with diesel though.
I just wondered if anyone used the DSE additive instead of heating the oil? Is it really snake oil?
  #2 (permalink)
Old 01-24-2008, 07:21 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Complete waste of your $$$$$$$ try this link: http://www.ford-trucks.com/forums/49...=Diesel+Secret
Do a search in this forum for "diesel secret" and you'll find more.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 01-24-2008, 11:46 PM
littledre1 littledre1 is offline
littledre1 is starting off with a positive reputation.
I think you would be better off investing in a good system to run WVO or SVO. I've done a bunch of research and have decided to get the Vegistroke system. I think you would be better off keeping the WVO and the diesel separate.
__________________
~Andre
2000, F350, Lariat, PSD, 4X4, CC, SB, 6spd, Vegistroke, BD Exhaust Brake ,
AIS with Fender Sleeve, SS HPX
315/75r16 Goodyear Duratracs, Milemarker Hydraulic Winch
  #4 (permalink)
Old 02-06-2008, 07:32 AM
lawngrease lawngrease is offline
lawngrease is starting off with a positive reputation.
It's Rumored that there is going to be system from Frybrid and Vegistroke that combines the best of both of their systems. I think that I heard that it may be available as early as later this year.
  #5 (permalink)
Old 02-06-2008, 07:34 AM
Quote:
Because of WVO tendancy to gell below 180 degrees, I completely agree on keeping them seperate.
  #6 (permalink)
Old 02-11-2008, 07:28 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
If you use good veggie, not lard or shortening, and you mix it with 20 % diesel in the summer time, more in the winter, it will run in my old 7.3, 6.9, and my two 93 Dodge truck. I haven't become brave enough to run it in my Powerstroke yet, I think I might try it next summer. The old Dodges will crank and run on the mixture even in winter, the old Fords I have to crank on diesel and swap to veggie in the winter time. As for you who say I will burn up my engine, it hasn't happened yet, and I have saved enough money to buy me a good used engine, and if I burn up my Ford, its getting a Cummins. I have decided I'm to be the test dummy for all you guys, and will post my results later. I have already saved enought money in each truck to fix it, so I'm going to keep trying until I tear somethin up. As for the DSE additive, I think its crap. I've got some, I ordered it see what the deal was, but never used it. I also make biodiesel, I mix that with my veggie in winter, plus run it straight in my Powerstroke.
__________________
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
  #7 (permalink)
Old 02-11-2008, 08:07 PM
firemediceric's Avatar
firemediceric firemediceric is offline
firemediceric is starting off with a positive reputation.
I have often said that DSE is preying and profiting on people's ignorance. DSE would have you believe that the process is much simpiliar and quicker than the often successful steps to blending are. That said, the fact that DSE is still around taking people's money is a testimonial that blending does work.
As someone who is active in reading on various forums, I haven't seen anymore negative first hand reports on blending than I have regarding two tank WVO systems and biodiesel.
I think there are many people that get started with DSE and then tweak the process to make a better quality fuel than one would with the simplistic DSE process. If DSE or the DSE type process was destroying as many vehicles as some would have you believe, I really think you would see more negative first hand reports than what I have been reading.
I guess I'm already the guinea pig on this venture. So far so good for the past almost two years.
__________________
1999 F-350 with Tymar type air filter, Dahl 100 fuel filter, HP oil X-over, bypass oil filter, coolant filter.
Tags
73, 95, additive, dse, powerstroke, run, running, tweak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
