Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-24-2008, 04:30 PM
articphoto articphoto is offline
Garage is empty, add now
articphoto is starting off with a positive reputation.
14 or 15 inch tires 1977 GT
How can i tell if my car takes 14 or 15 inch tires?
1977 Ranchero GT
  #2 (permalink)
Old 01-25-2008, 12:33 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
1977 Ranchero GT
There were 5 choices. The marked ID number is next to the valve stem.
D8OZ-1007-C = 1977 Ranchero with plain black painted wheels / Marked: CZ / 14" x 6.00" / 5" x 4.50"
D8OZ-1007-D = 1977 Ranchero with Styled Steel wheels / 5 spoke w/ 5 slots - MAGNUM 500 WHEEL* / Use with trim ring: D4WY-1210-A / Marked: HE or HG / 14" x 7.00" / 5" x 4.50"
D7OZ-1007-K = 1977 Ranchero with Styled Aluminum wheels / 26 spoke / Marked: D7OA-1007-BA or D7OC-1007-FWA (Dark Argent) / 15" x 6.50 / 5" x 4.50"
D7OZ-1007-H / Same as above except: Marked: D7OC-1007-FWA (Gold)
D7OZ-1007-J / Same as above except: Marked: D7OC-1007-FWA (Red)
*The Magnum 500 Wheel has been reproduced = dearbornclassics.com / online catalog / Page 121
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 01-29-2008, 09:27 PM
angus67 angus67 is offline
angus67 is starting off with a positive reputation.
judging by the other questions he has asked about his ranchero, (smoking, knocking. oil leaks,no fan belt) I seriosly doubt the original rims are still on it. 14 will fit but if you want performance tires, most choices come at 15" and up.post a couple pictures of your new buy, we could help you window shop!
  #4 (permalink)
Old 01-30-2008, 08:30 PM
StrokedRanchero StrokedRanchero is offline
StrokedRanchero is starting off with a positive reputation.
Late '70's Rancheros came standard w/14''rims. 15''were optional. If your lucky, your Ranch. WILL HAVE THE tire placard on the passenger side door jamb still. It will give you tire sizes & recomened optional sizes along with tire pressures & load limits.
  #5 (permalink)
Old 02-01-2008, 04:36 PM
It has "Rancheo" hubcaps.
Jiffy lube solved the problems, the guy I bought it from put water in the radiator so it froze when I brought it home. The oil leak is really a power steering leak.
It's not a primary car for at least 2 months, so I have time to get a good quote on that.
I do welcome input on aftermarket temp and oil pressure gauges, as these are probably sticking at 10F to -10F temps. I was thinking of putting them where the ashtray is.
  #6 (permalink)
Old 02-01-2008, 09:12 PM
even cheap gauges are better than idiot lights. easy to install. I use oil pressure, vaccuum, and coolant temp in my 67 fairlane. but remember you get what you pay for. my 'el cheapo' temp gauge sometimes dosnt move and I have to tap it to free the needle. autolites are sweet, and kinda pricey, but cheeaper than a new engine.
Tags
14, 15, 1977, d4wy1210a, d8oz1007d, f150, fit, ford, inch, magnum, ranchero, specs, tires, wheels, wheelstires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
