Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-24-2008, 11:27 AM
cjohnsd69 is starting off with a positive reputation.
Engine Stall - 2004 F150
Hey Guys,
I'm new to this site and I know there has been a lot of talk about Engine stall's, but I need some help !!
I have a 2004 F-150 Automatic 5.4 w/37,000 miles...My engine stalls while at low speed, such as sitting at a traffic light or going through a parking lot looking for a spot...The check enigne lite will come on, but wont give any codes...and will go away when the enigne is restarted....This only occurs at low speeds, the vehicle will run fine during normal driving....
The dealer had the vehicle for 3 days and couldnt find anything wrong with it,,,,
I just want to say thanks in advance for any assistance
CJ.....
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-15-2008, 06:53 AM
chrono4's Avatar
The bronco kid
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
Did you ever get this issue solved? Sounds like a bad or dirty IAC, or Idle Air Controller. I would suggest taking it off and cleaning good, and seeing if you can get it to happen again. If it still happens, then someone needs to put a scanner on it and test drive it until they can get it to do it again.
Who is pulling the codes? I would question if they are using the scanner correctly, because if the computer throws the light, it should save the code.
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
Technical Advisor
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
