1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Anyone running 35" or 37" tires with 4.10 or 4.30 gears?
Old 01-24-2008, 11:24 AM
sbechtold's Avatar
sbechtold
sbechtold is offline
I'm running 35" tires with a Donahoe Racing 4.5" lift. My truck is a F250 Lariat, 6.4, CC, SB, SRW with 3.73's. My truck feels down on power and my city and towing mileage have suffered significantly (~8 in the city and ~7 towing 8k#). I've done all my research on re-gearing to either 4.10s or 4.30's, but before pulling the trigger wanted to hear from anyone that is running a larger tire and has re-geared.
Any input on how performance and gas mileage is post re-gear?
Old 01-24-2008, 01:50 PM
V10_Cougar's Avatar
V10_Cougar
V10_Cougar is offline
Mos def on the 4.30, I run that on my 1999 with 35 in BFG's A/T and 6 inch lift which is now going to get 37in SuperSwamper. The 4.30 feel great. I have the V10 and it sure makes it a real puller but sucks gas, passes everything but a gas station.
Old 01-24-2008, 02:35 PM
sbechtold's Avatar
sbechtold
Thanks - I'm leaning towards the 4.30's.
Old 01-24-2008, 03:52 PM
OPTITRADER66's Avatar
OPTITRADER66
OPTITRADER66 is offline
I have a 250 crewcab 4x4 short bed 3.73 gears with 6" lift and 37.50 tires on 20x10" rims and have plenty of power and get around 12.5 city and 14 highway mpg.
Old 01-25-2008, 01:07 AM
gopedoligist's Avatar
gopedoligist
gopedoligist is offline
depends on your driving habits. if u mix town and highway then 4.30 would be good. if u do more town then i would think about 4.56, my cousin ended up goin with 4.56 and he is really happy with his town mileage
Old 01-25-2008, 07:55 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
Assuming your stock tires were 32 inches (just a guess), you need a 4.07 ratio (4.10 would be closest) to restore your truck to stock. Upgrade to a 4.30 ratio if you felt it was down a little on power before you upgraded the tires.
https://www.ford-trucks.com/calculat...e_sizes/a-er2/
Old 01-25-2008, 09:04 AM
ford97pwrstrk's Avatar
ford97pwrstrk
ford97pwrstrk is offline
i dont know what trany you guys have or motor i have a 97 f 250 with stock gears assume that they are 4:10 not really sure i run 37s and i am getting 18-21 mpg out of it all i have done is change the exhuast tat really helped and intake.. i do alot of high way driving during the week but still drive a lot of back roads around town and still always get at least 18mpg.. oh and i got a auto tranny so not sure if that makes any differents
Old 01-25-2008, 09:24 AM
Pocket's Avatar
Pocket
Pocket is offline
I'm running 4.30's on mine. Couldn't be happier.
Old 01-25-2008, 10:56 AM
GregsSD's Avatar
GregsSD
GregsSD is offline
I am running 4.30 with 35" tires and it is great because you get the power back that you lost from going with larger tires. I didn't see much of an increase in the mileage after changing gears, but it is well worth it for the power increase!
4.10 gears won't give you enough difference from the 3.73's to make it worth the cost. If you do alot of towing with your truck you would probably be happier going with 4.56 for the extra towing power.
Old 01-25-2008, 11:50 AM
joe blow's Avatar
joe blow
joe blow is offline
4.56's!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I run 37" tires and it is just a scosche below stock pulling. YOUR TRANSMISSION WILL LOVE YOU FOR IT. '04 F250 PSD 6.0
Old 01-25-2008, 12:53 PM
sbechtold's Avatar
sbechtold
Thanks for all the posts. I appreciate the input. I'm going with the 4.30's. I'll update this thread after the gears are installed and I get some miles on them.
UP_There
02-16-2017 08:43 AM
az4x4bronc
08-22-2016 02:07 PM
JimPat
04-04-2012 08:44 AM
mcjones44us
6.4L Power Stroke Diesel
01-26-2009 07:25 AM
cdrmotorsports
04-01-2007 09:32 PM
Quick Reply: Anyone running 35" or 37" tires with 4.10 or 4.30 gears?
