460 crankshaft - Ford Truck Enthusiasts Forums
460 crankshaft
Old 01-09-2002, 10:56 PM
TURBO TURBO is offline
TURBO is starting off with a positive reputation.
460 crankshaft
How much power can a stock 460 crank handle ?
Also what is better the internal or external balancing
1978 F-150 4x4
1998 Crown Vic Police Interceptor
Old 01-09-2002, 11:38 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
460 crankshaft
4-bolt main 460 cranks are virtually invincible.
2-bolt main 460's are weaker.
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old 01-10-2002, 01:00 AM
460 crankshaft
Is it the four bolt mains that make the difference or is
the crank different between the 4 bolt and the 2 bolt ?
Has anybody heard if a two bolt crank breaking because of too much power. I'm just curious what kind of HP and torque the stock two bolt will take, maby 550-600 HP or so?
What kind of power are some of you guys making with it.
1978 F-150 4x4
Old 01-10-2002, 09:41 AM
Metro2 Metro2 is offline
Metro2 is starting off with a positive reputation.
460 crankshaft
[updated:LAST EDITED ON 10-Jan-02 AT 09:45 AM (EST)]There is no such thing as a factory 4 bolt main 460.. Only a 429CJ -SCJ... You want a 4 bolt "460" block you need to get a SVO block from Ford. The 460 crank can take just about anything you can put to it... Just don't turn it above 7500 rpm...Remember it's a cast crankshaft... If your gonna turn above 6500 on a regular basis you need to make sure it's straight, deburred, shotpeened , indexed, equalized strokes, cross drilled, oil holes chamfered and micropolished... It's alot to have done, but it's a cast crank...As for the two bolt 460 block -- have it aligned honed with ARP studs and it will take plenty of abuse...For a performance application internal balancing is always better...Makes it alot easier if you decide the change flexplates,flywheels, pressure plates or balancers if its internally balanced...
Metro2
Old 01-10-2002, 07:59 PM
460 crankshaft
If you had one internally balanced and one externally balanced 460 side by side what would the difference be. How do you tell the internally balanced from the externally ?
I have two, one is a 76 and I think the other is a 77.
1978 F-150 4x4
Old 01-12-2002, 10:40 AM
bushman bushman is offline
bushman is starting off with a positive reputation.
Post 460 crankshaft
On the internally balanced engine there is a spacer behind the harmonic balancer that is just round, however on the externally balanced engine that same spacer has a counterweight sticking out from it.
Bushman
Old 01-13-2002, 12:39 AM
460 crankshaft
Thanks Bushman, I was beginning to think nobody would answer that question for me.
Both of them have round spacers behind the balancer.
1978 F-150 4x4
Old 01-13-2002, 10:43 PM
Just Strokin Just Strokin is online now
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
460 crankshaft
[updated:LAST EDITED ON 13-Jan-02 AT 10:46 PM (EST)]You will be surprised how much abuse a stock 460 crank can take. Lots of the 514's were built with stock 460 cranks offset ground and No2 pour on them. And they were not shotpeened, nor crossed drilled nor nitrided. As mentioned, the key is to say below 7500rpm.
Metro, they are now saying external balancing might be better for most applications like here. The flex is on the ends not in the middle where a crank tends to break.
One more thing, generally it is cheaper to externally balance a crank. Not always, but most times.
Old 01-14-2002, 12:58 AM
daywalker daywalker is offline
daywalker is starting off with a positive reputation.
460 crankshaft
I know of some books I've read (Ford F-Series Bible) that recomend pre-1979 460 cranks for racing because they were internally balanced.
Daywalker
92' F-250 351W ZF-5spd 4x4 4.10
78' Lincoln 460/C6
Old 01-15-2002, 07:49 AM
DeenHylton DeenHylton is offline
DeenHylton is starting off with a positive reputation.
460 crankshaft
Speaking from experiance...do not use a stroked 2Y cranks for racing, it WILL break...it just a matter of time. If your not going to buy an aftermnarket steel crank then stroke a 3Y crank, they have much smaller holes in the rod journal area and thereby much stronger when off-set ground. A stock stroke 460 crank should be good for 700-800 HP if you use the best of everything...clevite bearings, balanced assembly, restricted oil flow to the upper end, 4-bolt block(prefered) or at least
ARP main cap studs. I saw evedence of "cap-walk" even on my SCJ 4-bolt bottom end with 3Y stroked crank (514 ci.). I spun it to 7,600 RPM many a time. Deen
Old 01-15-2002, 06:02 PM
460 crankshaft
My plans are to just have the stock crank turned and shotpeened, I am not building a stroker. I am going to have Milodon splayed 4 bolt main caps put in the block. I hope this will be strong enough for 700-750HP.
Thanks for the info guys
1978 F-150 4x4
Old 01-20-2002, 08:06 PM
mud_man mud_man is offline
mud_man is starting off with a positive reputation.
460 crankshaft
I have a 460 .60 over bore,460 crank. balanced, dove heads ported and polished,stalth intake,crane solid,cam 624 lift 276 dur, deamon carb,at6000 it is 624 hp 546 torque have ran it 4 years with no trouble mud raceing
Old 01-21-2002, 12:36 PM
georgedavila georgedavila is offline
georgedavila is starting off with a positive reputation.
460 crankshaft
If you plan to run it above 6000rpm, it'll be the rods that give you problems, not the crank. There are a ton of boats out there running stock (balanced, polished, oil holes done) cranks and 2-bolt blocks at 5-650hp wide-open all day long, but above that takes rpms in excess of what the stock or CJ/Truck rods will handle. 460 crank failure for balanced and properly prepared engines that stay around 6000rpm with stock rods and way above that with aftermarket rods just isn't that common.
Old 01-22-2002, 05:14 PM
460 crankshaft
Yea, I have heard alot about stock rods being the weak point in the 460s bottom end and I WILL NOT be using them.
1978 F-150 4x4
Old 01-22-2002, 09:31 PM
460 crankshaft
351 to 460 swap Granny Gear 1973 - 1979 F-100 & Larger F-Series Trucks 16 06-24-2012 08:25 PM
Need: stock 460 engine towers 4x4?? zakt 1973 - 1979 F-100 & Larger F-Series Trucks 33 08-18-2009 12:33 AM
Am I the only one with a 460 as a daily driver? gthbryce 1987 - 1996 F150 & Larger F-Series Trucks 30 05-06-2009 04:47 AM
460 flywheel problem johncart 1967 - 1972 F-100 & Larger F-Series Trucks 40 09-29-2008 01:05 AM
1991 460 cams? Justin460 1987 - 1996 F150 & Larger F-Series Trucks 0 12-12-2007 04:17 PM
Tags
460, 460crankshafts, bolt, breakage, camshaft, cast, counterweight, crank, crankshaft, ford, handle, harmonic, issue, key, main, power
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
