460 valve adjustment - Ford Truck Enthusiasts Forums
Old 01-19-2002, 08:10 AM
crewcab77's Avatar
crewcab77 crewcab77 is offline
crewcab77 is starting off with a positive reputation.
Can anybody tell me if the 460's have adjustable valves or do you just torque them? And if there adjustable How do you do it? And if there just torqued how much? Randy
Old 01-19-2002, 12:41 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
AFAIK,
Hydralic valve settings with a NON-Positve stop are
adjusted by turning the nut down 1-1 1/2 turns after
clacking quits.
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old 01-19-2002, 08:06 PM
Old 01-19-2002, 11:27 PM
greenhighboy's Avatar
greenhighboy greenhighboy is offline
greenhighboy is starting off with a positive reputation.
It won't have adjustable valves unless someone changed them to adjustable.They should torque to 22lbs.
Dennis
1979 F-250 4x4 460 4-speed 33"s
1977 Highboy 429 4-speed 35"s
1969 Ranger on a 1978 F-250 4x4
frame 466 560HP 4.10's 33"s
Old 01-22-2002, 09:45 AM
georgedavila georgedavila is offline
georgedavila is starting off with a positive reputation.
If they're '68-71 heads, the best thing you can do is install a set of Crane Kool Nuts. They have an Allen set screw that'll allow you to adjust your hydraulic lifter preload. This is especially important if you're running an aftermarket cam. If you've been just tightning them down to 22lbs and then go to the Kool nuts with a lifter preload of 1/4-1/2 turn, you'll notice a big difference in idle and performance.
Old 01-22-2002, 09:36 PM
I was on Cranes websight awhile back and saw that putting those on made the valves adjustable, then couldn't believe how cheap they were.They were less than $30.I just rebuilt my 429 with 72 heads and had to use the shims to adjust pre load it was a PITA.
Dennis
Old 11-12-2008, 12:33 AM
1974fordtruckman 1974fordtruckman is offline
1974fordtruckman is starting off with a positive reputation.
I have a 460 in a 1974 F350 one ton Can I use the Kool Nuts to make my valves adjustable on this motor
Thanks for any info you can give me. Larry
Old 11-12-2008, 12:53 PM
460me's Avatar
460me 460me is offline
460me is starting off with a positive reputation.
Quote:
Dennis
Didn't know about the nuts.My 79 460,I did the shim thing and wasn't that bad,You just need to take your time and do it right the first time
Old 11-12-2008, 03:39 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
it depends on what heads you have as to how easy it is to convert to adjustable rockers.
the early heads (C8, C9 and DOVE) heads all used screw in rocker studs, so you can either change these out to aftermarket studs, guide plates and the cool nuts to have adjustable rocker arms (or you could just use the cool nuts as long as you don't need to adjust past the neck on the studs)
on the later heads (D3VE) they used a bolt down style rocker arm with a milled pedastle and bolt that are non-adjustable. you either have to shim or get different lenght pushrods to adjust.
I think either Crane or Comp cams makes a kit to convert these to adjustable rocker arms. not sure what is all involved or needed to do this conversion. or you could go the machining route and mill off the slot and redrill and tap to accept rocker studs.
rgds
Mike
Old 11-13-2008, 12:18 PM
C-Leigh Racing C-Leigh Racing is offline
C-Leigh Racing is starting off with a positive reputation.
Hello, new member here, first reply.
I'm seeing that Crane offers a pushrod guide set for the 460 heads that use the lock down fulcrum rockers. The guide is made to fit right into the slot where the squaire fulcrum suppose to sit & has 5/16" flanged screw in stud holding the guide in place. Has a peice the slips into the end of the guide that the pushrod goes through I guess for reducing wear.
Crane also has adjustable pushrods for the B/B, pushrods you can run, with oil passage, not just the checking adjuster type, but be ready to spend around 250.00 or more.
This replys NOT intended to be an addvertisment for Crane, just what I have learned in the almost 2 years dealing with the 460 I am trying to keep running.
Neil
adjusting valves rockcrawler_101 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 06-10-2011 06:46 PM
reinstalling non adjustable rockers marcograms 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-18-2010 09:29 PM
Valve Adjustment fordflaresides Ford Inline Six, 200, 250, 4.9L / 300 0 11-23-2005 02:11 AM
302 valve adjustment edder Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 09-03-2003 12:10 AM
1973 Ford 302 valve adjustment bozweed Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 07-09-2003 12:04 PM
Tags
460, 64, adjustment, arm, cams, cbr, conversion, crane, dead, ford, guide, hydraulic, lifter, preload, pushrod, rocker, valve, walking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
