429 vs. 460 what do I have?
Old 01-09-2002, 08:28 PM
TURBO's Avatar
TURBO
TURBO is offline
Is there any way to tell the difference between a 429 and a 460
without removing a head and measuring the stroke. The reason I ask is I have either a 429 or a 460 but I'm not shure which it is. The valve cover sticker says its a 460 but the flexplate has 429 written on it with grease pencil and it appears to have different balancing holes drilled in it than the known 460 I have. Is there any way to tell by casting #s what it is. If there is I will get them and post them.
1978 F-150 4x4
1998 Crown Vic Police Interceptor
Old 01-09-2002, 10:35 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Casting Numbers is the easiest way to tell.
The 429 was discontined in what 71.
Block,Intake and Head numbers will do fine.
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old 01-09-2002, 11:48 PM
TURBO's Avatar
TURBO
TURBO is offline
Went out to the barn and got the numbers, here they are.
Block = D1VE-6015-A2
Intake = D6VE-942? (the rest was ground off for some reason)
Heads = D3VE-A2A
Dont the 429 and 460 use the same block though ?
1978 F-150 4x4
Old 01-10-2002, 01:42 PM
TURBO's Avatar
TURBO
TURBO is offline
Also, I don't know if this means anything, but the starter looks like a GM starter with a Ford nose cone
1978 F-150 4X4
Old 01-10-2002, 02:21 PM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
One of the easiest, but may not be reliable since I have never verified it, but here it is.....
The 429 damper is closer to the timing cover than on a 460. The 460 used a spacer between the damper and the timing cover.
Old 01-10-2002, 03:35 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
>Heads = D3VE-A2A
******460*******
>1978 F-150 4x4
Dennis
Old 01-10-2002, 06:51 PM
TURBO's Avatar
TURBO
TURBO is offline
Just Strokin-
It does have the same spacer between the timing cover and the balancer that my other 460 has.
So it looks like it's pretty safe to say it's a 460.
Thanks guys
1978 F-150 4X4
Old 01-11-2002, 06:17 AM
Just Strokin
With the late casting number on the Intake, you can almost rest assured it is a 460, not always. The thing to do would be pull the oil pan and look for the crank number.
Old 01-13-2002, 10:35 PM
TBirdGuy's Avatar
TBirdGuy
TBirdGuy is offline
What's the motor out of? I do know of 429's being produced past 71' in heavy duty trucks.
TBirdGuy
Old 01-19-2002, 04:06 AM
TURBO's Avatar
TURBO
TURBO is offline
I got it from a 76 Murcury Montego. The guy I got the car from said it originally had a 400M and he swapped this one in, but he did'nt know if it was a 429 or a 460 or what it came from originally.
1978 F-150 4x4
Old 01-20-2002, 06:54 PM
mud_man's Avatar
mud_man
mud_man is offline
the crankshaft is how you till cast no, on 429 are
4u or4UA
460 are
2y 2ya 2yab 2yabc
Old 01-22-2002, 04:05 PM
TURBO's Avatar
TURBO
TURBO is offline
Where are the #s located on the crank, are they on the flywheel end or do I have to remove the pan to see them ?
I'm not going to be back home untill friday, I'll check then.
Thanks or
1978 F-150 4X4
Old 01-22-2002, 06:00 PM
mud_man's Avatar
mud_man
mud_man is offline
remove pan there are on side of one of the cranks not sure were I would need to look tofind but they are there
Old 01-22-2002, 06:21 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
It should be on one of the throws.
Dennis
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=144&.jpg
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=143&.jpg
Old 01-22-2002, 08:14 PM
bigsnag's Avatar
bigsnag
bigsnag is offline
Quick Reply: 429 vs. 460 what do I have?
