Transmission and axle code ID - Ford Truck Enthusiasts Forums
Old 01-24-2008, 12:23 AM
Art Art is offline
Art is starting off with a positive reputation.
I am pretty good with the older trucks (67-79, I currently own 6+ of them), but am looking at purchasing a newer one - a 1993 F700 to replace a brand-X dump truck. Anyways, this F700 is Cummins 5.9 powered and has a 5speed transmission and a 2speed rear axle. The door tag code for the transmission is "CX" and the code for the axle is "W1". Can anyone look that up and identify them? Obviously it is too new for my 60's and 70's Ford service manual listings... Thanks in advance,
Art
Old 01-24-2008, 09:26 AM
Art Art is offline
Anyone have a 1993 Service manual?
Old 01-24-2008, 10:14 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
CX= Eaton F5-4005B 5-Speed.
The 93 manual does not list a W1 rear end, is this a single or Tandem?
Old 01-24-2008, 10:17 AM
Art Art is offline
It is a single axle truck with a two-speed axle with Dayton (not Budd) wheels.
Old 01-24-2008, 10:26 AM
subford's Avatar
OK I see it now.
W1= Description, RS-17-220 Ratio, 4.30:1/6.00:1
Old 01-24-2008, 10:29 AM
Art Art is offline
Thank you very much.
Art
Old 01-24-2008, 10:34 AM
subford's Avatar
Art
I posted an error above.
Old 01-24-2008, 10:51 AM
Art Art is offline
I am not sure what you mean. It appears the two posts list the same text. Did you mean "FS" instead of "F5"?
Art
Old 01-24-2008, 11:31 AM
subford's Avatar
Art
I had CX= Eaton F5-4006B 5-Speed above but changed it to CX= Eaton F5-4005B 5-Speed.
And now that I look at again (it is not very clear) it looks like:
CX= Eaton FS-4005B 5-Speed.
There is no space between the F & S but I can not get rid of the space in the post.
1980-1986 axle code chart needed Art 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 09-19-2014 02:58 AM
Front disc brake shields for 79 4wd with dual piston calipers Art 1973 - 1979 F-100 & Larger F-Series Trucks 9 03-29-2011 06:55 AM
FAQ - Axle Code Charts Art '80-'86 FAQs (Frequently Asked Questions) 3 04-08-2009 07:40 PM
axle code 73 on a 1985 F350 Art 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 03-29-2009 09:47 PM
VIN location on frame of 1979 4x4 Art 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-13-2002 03:07 AM
Tags
1993, axle, codes, door, f700, ford, id, rear, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
