Ok so heres an update on what I've found.......I still dont' know route cause.
The top of the head is dry, but its wet at about the middle of the exhaust manifold and down the block. The head gasket was dry, then I started the engine and the gasket was wet from the middle of the exhaust manifold to the front. I can't physically see any leaks coming from the head. There are puffs of white smoke from the exhaust maifold.
There doesn't appear to be any antifreeze in the oil and there are external coolant leaks. The antifreeze doesn't appear to be oily.
Thoughts so far......freeze plugs or head gasket. Do you guys have any other ideas?
The truck runs/idles well, the exhaust doesn't smell sweet, the truck runs at normal temp.
I have an appt this week at the dealer to have them diagnose it.
