Just for now check the wiring back to the PCM if possible I tried to send a message with PCM info but MIL email dumped the attachment.. they notified me.
The PCM ground(s) are in position pin #20...... which is circuit #57 a black wire.
Also pin #60 ... which is circuit #570 a black and white wire. I would remove the PCM wire cover and check in there.
FYI the yellow wire is in position#1, there are 3 rows of 20, starting at 1/21/31 up to 60.
I'll probably get to it on Saturday.....gotta go to work for the afternoon tomorrow....I love being a helo pilot....
THANKS a TON
Thad
__________________
1994 F350 XL Crewcab 4x4 SRW 7.3 NA
Dana 60 Sterling 10.25 3.55 285/75 16 Dayton Timberlines
TC lockup Mod
Pyro Installed
TO DO: Boost guage, Install Tekonsha Voyager Brake controller and Turbo when I acquire one!!!
A little rough but its a truck not a show car!!!
In its former life it worked for the US GOVT
I wish you were a hot girl so I could kiss you.......
When I set it to DC and did it everything checked out on the middle wire.
1.2 @ idle to 4.0 @ WOT
Thanks, you are a Godsend
Pete thanks for trudging along with me on this one!!!!!
__________________
TC lockup Mod
Pyro Installed
It was acting up only (I think) because the FIPL was never adjusted properly due to my using the wrong setting (AC instead of DC) on my voltmeter. Dave Sponaugle suggested I use DC instead of AC and it worked.
Thanks Again
Thad
__________________
TC lockup Mod
Pyro Installed
Now I am on to conquer the 4x4 problems my pickup has.....
__________________
TC lockup Mod
Pyro Installed
Well, on second after thought seeing the picture my wife may have to do the kissing....lol
But seriously I cant thank you enough. One day I'll understand why that was a big deal.....for now I am satisfied with a running pickup......
Thad
__________________
TC lockup Mod
Pyro Installed
Since everyone talks about that joker in the snow plow that plows their driveway shut right after they shovel it out, I found a good hat to wear while plowing.
They are laughing so hard they can't be mad after I go by.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
So now we know the whole story....I was wondering what you meant by "snow joker".
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
I am going out to check on these grounds.....I may have more questions very soon....
Thad
__________________
TC lockup Mod
Pyro Installed
The #1 wire (yellow) has 12 volts DC when I put the voltmeter on it (I had the negative lead on the negative battery post). It shouldnt have reading, should it?
__________________
TC lockup Mod
Pyro Installed
