loose gas cap light associated with check engine light?
My check engine light is on in my 2004 f 250 5.4 for a possibly bad purge valve. The loose gas cap light has also been coming on and off for no apparent reason. Is there anyway the two could be related? The code i got was PO443 which if i remember right indicates a leak in the emissions system. any response would be appreciated
There's a loose gas cap light?
P0443 is Evaporative Emission Control System Purge Control Valve Circuit
EDIT: I checked the manual at
http://www.analogstereo.com/pdf/om/f...anual_2004.pdf
and yes, there is a Check fuel cap light!
78'fordtruckguy
1999 to 2016 Super Duty
04-12-2010 01:59 PM
