I Need Some Feedback!
The 300 I6 I have in my truck need's some work done.I have to pull the motor to drop the pan.I'm not sure what the problem is,makes a knocking noise.So my delema is,-I found a another 300,I'm just waiting for the wrecker to do the compression test and all that.If the motor is good should I buy it,do the re'n're, then tear down the original 300 and re-build it proper?What do you guy's think?The main reason I'm thinking about this route,is so I can keep driving my truck.I really don't know how long it would take me to re-build the motor.And besides 2 300's could reall be an advantage to me.
I had a 300 that a piston skirt broke off.I pulled the head and pan and the piston.Had a machine shop press a new piston on and had it all back together in less then a day.Never had another problem with it.Unplug a sparkplug wire one at a time to hear the sound change will tell you which cylinder.Cost was minimal.
I might mention that when it started knocking I shut it off right away so it didnt have time to do any other damage.
