engine heater - Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
engine heater
Old 01-23-2008, 10:15 AM
jkbeegs jkbeegs is offline
jkbeegs is starting off with a positive reputation.
engine heater
Living in Iowa can you leave your engine heater on for a long period of time on a 2006 6.0 liter diesel engine?
Old 01-23-2008, 12:04 PM
67nukeford's Avatar
67nukeford 67nukeford is online now
Nebraska Chapter LDR
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
I've had mine on since Sunday! I don't think it's a big deal when it's this cold.
Old 01-24-2008, 06:43 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Do it all the time with trucks, tractors, the only thing it affects is the power bill, and really, it doesn't hit that too bad, something like 15 cents a day to be plugged in.
Old 01-24-2008, 05:00 PM
428HIGHBOY 428HIGHBOY is offline
428HIGHBOY is starting off with a positive reputation.
Only 15 cents? How many watts?
Old 01-24-2008, 05:39 PM
fellro86's Avatar
That was a friend telling me what it cost to keep their semi plugged in.
Old 01-24-2008, 09:03 PM
fellro86's Avatar
I just remembered a little test I did a while back, had my dad's 84 plugged in, and watched the meter. By the numbers given on that, it was on track to cost about $30 a month if it were plugged in 24/7.I read the meter at the same time 24 hours apart, and our power is about 10 cents a kilowatt/hour if I remember correctly.
Old 01-24-2008, 09:14 PM
24 hours x 30 days =720 hours
500 watts / 1000 (kilo) = .5 kilowatt
720 hrs x .5 kw = 360 kilowatt hours
10 cents x 360 kwh = $36
Old 01-26-2008, 08:50 AM
beaners1 beaners1 is offline
beaners1 is starting off with a positive reputation.
They make little meters to check electrical usage, just plug it in then plug in whatever, tells you how much it uses. Bought mine for $45 and I found out I needed a new deep freeze pretty badly. Kinda nice to know what uses what.
Old 01-26-2008, 06:11 PM
Ohms law works too. E=I X R
Old 01-27-2008, 06:50 AM
fellro86's Avatar
Ohms is nice for estimates, but without knowing the actual resistance and current, it is an educated guess. Ratings don't guarantee usage. I do know what themeter said for usage, so that's why I went that way. (Not to mention, forgot to try figuring it by Ohm's law...)
Diesel fuel and cold weather question buckmasters 6.7L Power Stroke Diesel 6 10-30-2011 09:05 AM
GPR - 110 iowa 7.3 1999 - 2003 7.3L Power Stroke Diesel 14 04-26-2011 11:13 AM
How long to keep diesel engine heater plugged in? jkbeegs Testing..... 0 01-22-2008 06:30 PM
Does Diesel Fuel Thicken Below Freezing? danonbar 1999 to 2016 Super Duty 12 01-22-2005 10:11 PM
Engine Block Heater Question F150y2k Cooling, Heating, Ventilation & A/C 3 08-06-2003 10:24 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
