1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Airbag Steering wheel removal
Old 01-22-2008, 07:17 PM
F350-6's Avatar
F350-6
F350-6 is offline
I’ve seen a couple of people asking about this so I thought I would post some instructions w/pics on air bag removal. I’ll also include the steps for steering wheel removal since we’re almost that far. If I leave anything out let me know.
<o> </o>
1) Make sure wheels and steering wheel are pointed straight ahead.
2) Put on a pair of safety glasses just in case.
3) Disconnect the negative battery cable (both if it is a diesel) for at least 1 minute. I disconnected both negative & positive from both my batteries and let it sit for 10 min. because I don’t like things going boom in my face.
4) Remove fuse access panel and check for voltage at fuse panel. Not necessary, but see comment in note 2.
5) To the right of the under dash fuse panel there are 2 plugs next to each other (see pic) Unplug the black smaller plug to disconnect the drivers air bag. Disconnect the bigger gray plug that goes to the cruise buttons if you are pulling the wheel or need to check the wires for continuity.
6) Open & empty glove box. Squeeze the sides in gently past the stops so the glove box door opens to the floor. Look up and unplug the passenger air bag connector just for safety sake.
The following users liked this post:
Old 01-22-2008, 07:18 PM
F350-6's Avatar
F350-6
F350-6 is offline
7) Locate and remove (pry out) the 2 plastic round covers on the back of the steering wheel.
8) Remove the 5/16 head bolt from behind each plug. If you look closely inside the hole there is also a torx head screw. No need to worry about this screw leave it alone. See blurry pic & 2<sup>nd</sup> pic
9) After removing these 2 bolts, gently lift the air bag off the steering wheel.
10) Disconnect the 2 wiring plugs off the back of the air bag and set the air bag in a safe location out of the way where it will not be bumped or disturbed.
Old 01-22-2008, 07:19 PM
F350-6's Avatar
F350-6
F350-6 is offline
11) Look at whatever possessed you to come this far in the first place.
Old 01-22-2008, 07:21 PM
F350-6's Avatar
F350-6
F350-6 is offline
12) To remove steering wheel unscrew the torx screw in the center of the steering wheel.
13) Using a 2 jaw puller remove the steering wheel.
14) As the book likes to say “To install, reverse procedure”
<o> </o>
Let me know what I left out or if anyone needs more info.
Old 01-22-2008, 07:38 PM
F350-6's Avatar
F350-6
F350-6 is offline
If you want to check continuity in your steering column cruise control wires the diagram for that is here.
Old 01-22-2008, 08:17 PM
JEB70's Avatar
JEB70
JEB70 is offline
Great write up and you included pics as well - couldn't ask for anything more in a how to thread....
Old 01-23-2008, 07:53 AM
vettdvr's Avatar
vettdvr
vettdvr is offline
Very professional write up,, thank you.
Old 01-23-2008, 08:18 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Great job Chris.
Old 01-23-2008, 10:14 AM
89LX306's Avatar
89LX306
89LX306 is offline
Good job. With the correct procedure this is an easy job, but most people are scared of the process. I did my 04 Expedition a year or so ago when I repaired the cruise control switches.
One other thought...When setting the airbag aside, set it face up. Setting it face down could result in it becoming a projectile if it accidentally deployed.
It is not a hard job, but definitely something to take the proper precautions with.
Old 01-23-2008, 10:46 AM
blueknightcrew's Avatar
blueknightcrew
blueknightcrew is offline
Thanks, Great info,and just in time for my next project. I'm up to the task at hand now and look forward to a safe and easy installation.
Thanks again, Ron
Old 01-23-2008, 05:39 PM
F350-6's Avatar
F350-6
F350-6 is offline
Sorry guys. I just noticed I posted the wiring schematic for the Econoline. Here's the Super Duty one. Also this is all based on my 2002 truck.
Old 01-23-2008, 08:40 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
Chris, any advice on how to test the airbag controller/sensors and clockspring? I'm doing a rebuild and need to replace driver's airbag (passenger side was turned off).
Old 01-23-2008, 08:46 PM
jeff7825's Avatar
jeff7825
jeff7825 is offline
Great write up Chris. You definately know what your doing. Very thorough
Old 01-23-2008, 09:12 PM
F350-6's Avatar
F350-6
F350-6 is offline
Do you know the clockspring is bad? It sits just under the steering wheel. Once the steering wheel is removed you can remove the clockspring and wiring harness for replacement. If you need more info let me know.
As far as replacment of the air bag the manual says this (condensed version)
Driver Air Bag Module <o></o>
Removal <o></o>
WARNING: If replacing a deployed air bag module, always replace the air bag electronic crash sensor (ECS) module. <o></o>
WARNING: After deployment, the air bag surface can contain deposits of sodium hydroxide, a product of the gas generant combustion that is irritating to the skin. Wash your hands with soap and water afterwards. <o></o>
WARNING: Never probe the connectors on the air bag module. Doing so can result in air bag deployment, which can result in personal injury. <o></o>
WARNING: Air bag modules with discolored or damaged trim covers must be replaced, not repainted. <o></o>
NOTE: Repair is made by replacement only. If a part is replaced and the new part does not correct the condition, install the original part and perform the diagnostic procedure again. <o></o>
<!--[if !supportLists]-->1.<!--[endif]-->Prepare the vehicle for driver air bag module removal. <o></o>
<!--[if !supportLists]-->2.<!--[endif]-->Remove the driver air bag module. See above<o></o>
Installation <o></o>
Install the driver air bag module. <o></o>
<!--[if !supportLists]-->1.Connect the horn electrical connector. <o></o>
<!--[if !supportLists]-->2.<!--[endif]-->Connect the driver air bag module electrical connector. <o></o>
<!--[if !supportLists]-->3.<!--[endif]-->Position the driver air bag module into the steering wheel. <o></o>
<!--[if !supportLists]-->4.<!--[endif]-->Install the two bolts. <o></o>
<!--[if !supportLists]-->5.Install the two steering wheel back cover plugs. <o></o>
Restore the vehicle to operating condition. <o></o>
Prove Out Procedure
Turn the ignition switch from the OFF to the RUN position and visually monitor the air bag indicator with the air bag modules and safety belt pretensioners or restraint system diagnostic tools installed. The air bag indicator will light continuously for approximately six seconds and then turn off. If an air bag supplemental restraint system (SRS) fault is present, the air bag indicator will either: <o></o><o></o><o></o><o></o>
The flashing might not occur until approximately 30 seconds after the ignition switch has been turned from the OFF to the RUN position. This is the time required for the restraints control module (RCM) to complete the testing of the SRS. If the air bag indicator is inoperative and an SRS fault exists, a chime will sound in a pattern of five sets of five beeps. If this occurs, the air bag indicator will need to be repaired before diagnosis can continue. <o></o>
Old 01-23-2008, 11:52 PM
Topbob's Avatar
Topbob
Topbob is offline
Appreciate the info re: airbag/steering wheel removal; as others have said, good work.
Question: does steering wheel have a master spline or should it be marked for alignment before removal? Thanks.
My experience all comes from bad judgement; am still waiting for good judgement
Quick Reply: Airbag Steering wheel removal
