How much does a 28 gallon tank actually hold? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-22-2008, 05:42 PM
CruiserClass CruiserClass is offline
CruiserClass is gaining momentum as a positive member of FTE.
OK, I feel like a tard asking "Derrr, how many gallons does a 28 gallon tank hold?" but, um, how many gallons does a 28 gallon tank hold?
The reason I ask is while I was traveling to Georgia I filled up and the pump said I took 33 gallons. I really figured I'd gotten screwed by a inaccurate pump meter, so since then I've let the fuel light come on a time or two just to see. I've used several different pumps around town and have put in between 28.7 to 30.5 gallons. That's letting the foam die down and topping off several times.
So, is every gas station cheating me or does a 28 gallon tank actually hold over 28 gallons because of the filler neck, etc. If so, what's the actual capacity?
Old 01-22-2008, 05:48 PM
Vijay's Avatar
Vijay Vijay is offline
Vijay is gaining momentum as a positive member of FTE.
I have a 38 gallon tank and on HW pumps it stops at 33 or so...
Old 01-22-2008, 06:21 PM
Momorris Momorris is offline
Momorris is starting off with a positive reputation.
My truck is the same way, I've been curious of this myself.
Old 01-22-2008, 06:22 PM
firesoutmatt's Avatar
firesoutmatt firesoutmatt is offline
firesoutmatt is starting off with a positive reputation.
Yes you can put 6-7 gals more than spec.
If you have heard of the harpoon mod this will help filling full without waiting for the foam to go down.
33 gals I wouldn't let it get that empty . Injectors on a 6.0 need all the fuel they can get .
BTW I just assumed you had a diesel when you said you had to wait for the foam to die down . If your a gasser don't worry about it.
Old 01-22-2008, 06:49 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
What truck has a 28 gallon tank? I thought short bed trucks have 29 gallon tanks, long bed trucks have 33 gallon tanks
Old 01-22-2008, 06:54 PM
mackstruck mackstruck is offline
mackstruck is starting off with a positive reputation.
Mine has a "29 gal." tank. and the most I have ever been able to put in it the last six years was about 26 gallons. The needle was about a 1/4 in. bellow the empty. Most of the time it is about 24 to 25 gallons.
I think you got taken.
Old 01-22-2008, 06:56 PM
pyro2nite's Avatar
pyro2nite pyro2nite is offline
pyro2nite is starting off with a positive reputation.
Quote:
I think the long bed has a 38 gallon and the short has a 30.
Old 01-22-2008, 08:11 PM
boxcar1974's Avatar
boxcar1974 boxcar1974 is offline
boxcar1974 has a good reputation on FTE.boxcar1974 has a good reputation on FTE.
Short beds are 29 in the 99-07 trucks. Not sure about the 08's
Old 01-22-2008, 10:16 PM
Grey 250s's Avatar
Grey 250s Grey 250s is offline
Grey 250s is gaining momentum as a positive member of FTE.Grey 250s is gaining momentum as a positive member of FTE.
The book for my '06 long bed says it has a 38 gal tank but I've never been able to put more than 33 in it. I keep telling myself I have a bit of reserve after the message center says I'm low on fuel. I'm too skeered to run it dry so I don't really know.
Old 01-22-2008, 11:14 PM
That_Guy's Avatar
That_Guy That_Guy is offline
That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.
Quote:
Ive ran mine mine past the point when the message center says "0 miles till empty" so i think there is some more still left in the tank also, dont want to find out how much is exacty left in there though lol
Old 01-23-2008, 12:20 AM
GregsSD's Avatar
GregsSD GregsSD is offline
GregsSD has a very good reputation on FTE.GregsSD has a very good reputation on FTE.GregsSD has a very good reputation on FTE.GregsSD has a very good reputation on FTE.
When I bought my truck, the window sticker said 28 gallon tank but the brochure said 29 gallon (or visa-versa). But after doing the harpoon mod to the tank I now regularly put in 30-31 gals.
Old 01-23-2008, 05:29 AM
toddyw toddyw is offline
toddyw is starting off with a positive reputation.
Ford makes one fuel tank, the same tank is install whether it is gas or diesel. For what ever reason the gas system requires an expansion area above the surface of the gas, probably emission controls, the diesel does not require the expansion space. To have this space above the surface of the gas, the fuel tank vent protrudes 5" to 6" inches into the tank. When you "Harpoon" the tank, the tank is removed and opened, using a PVC pipe cutter, the vent and fill pipes are cut as close as possible to the top of the tank and this allows for extra capacity and quick filling of the fuel tanks, about 33 USG in the 28 USG tank, and about 42 USG in the 38 USG tank.
Old 01-23-2008, 08:24 AM
redford's Avatar
Quote:
That is not correct. Ford makes 2 different size tanks for the long bed and short bed trucks.
Old 01-23-2008, 08:31 AM
cgl cgl is offline
cgl is gaining momentum as a positive member of FTE.
I think he was saying there is no difference between the gas or diesel tanks. He does mention both the 29 and 38 gallon tanks at the end of his post.
Old 01-23-2008, 09:44 AM
Quote:
Originally Posted by GregsSD
...the window sticker said 28 gallon tank but the brochure said 29 gallon (or visa-versa)...
Same here. 1999 F-250 supercab/shortbed with 7.3. Capacity was listed as 28 gallons for shortbed, 38 gallons for longbed.
how close have you cut it on the gas game auburngrad 1999 to 2016 Super Duty 26 05-17-2015 10:00 AM
Fuel Level System Problems jrwendell 6.7L Power Stroke Diesel 6 06-14-2011 07:01 AM
Gas tank capacities? GBuckert 1987 - 1996 F150 & Larger F-Series Trucks 5 05-02-2011 01:04 PM
Fuel Tank Size/Range gpfarrell 2007 - 2014 Expedition & Navigator 11 04-21-2010 11:04 PM
Gas Tank Size Mike Cook Bronco II 11 05-12-2004 12:58 PM
Tags
2008, 28, 6l, cost, duty, f250, ford, fuel, gallon, gallons, hold, super, superduty, tank, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
