1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How much does a 28 gallon tank actually hold?
Old 01-23-2008, 09:51 AM
firesoutmatt's Avatar
firesoutmatt
firesoutmatt is offline
Originally Posted by redford
That is not correct. Ford makes 2 different size tanks for the long bed and short bed trucks.
Yes but read his statement all the way to the end. Todd is correct on his answer .
Old 01-23-2008, 10:18 AM
SBastow's Avatar
SBastow
SBastow is offline
how many gallons
where do I find out what size tank is in my truck. 99 F-250 reg. cab long bed
Old 01-23-2008, 10:22 AM
HeavyAssault's Avatar
HeavyAssault
HeavyAssault is offline
Topping off my 38 gal LB tank will require me to add an extra 3-4 gal OVER the pump automatic shutoff. I don't consider the Harpoon mod a method of INCREASING the tank capicity but a way to allow filling to the cap much quicker due to the foam backing up the fill neck.
Either tank you use (29gal SB or 38gal LB) can be filled up the neck to the tune of a few extra gallons. I can drive close to 300 miles on the first quarter of the tank. After that it drops like a rock.
Do we need to do a MythBusters test on this topic?
Old 01-23-2008, 02:25 PM
firesoutmatt
Long bed = 38 gal
Short bed = 29 gal
+ 4 to 6 gals if you fill to top of the neck.
Old 01-23-2008, 02:43 PM
mizzitch's Avatar
mizzitch
mizzitch is offline
I once put in 31.5 gallons. 99 CC SB
yugger
2017+ Super Duty
08-08-2017 06:26 AM
big315
08-11-2016 06:43 PM
gtinswva
03-15-2013 03:26 PM
gpfarrell
04-21-2010 11:04 PM
Mike Cook
Bronco II
05-12-2004 12:58 PM
Quick Reply: How much does a 28 gallon tank actually hold?
