Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-22-2008, 08:19 AM
scotv is starting off with a positive reputation.
Rebuilding 351 C
I am planning on rebuilding my 351C to make 275 hp. Are roller rockers going to help my power gains?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-22-2008, 11:38 AM
Mike G is starting off with a positive reputation.
First off, welcome aboard!
Secondly, tell us a little more about the motor. What vehicle was it out of, is it currently running, what other components are you putting into it....
--Mike
__________________
Mike G
1965 F100 LWB .060 over 390/beefed C6
1968 Cougar XR7 (wife's toy)
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
2003 XR50 w/big bore 80cc kit
1990 Chaparral 2000SL 20ft bow-rider 5.7L Merc
Yes...there are only three licensed drivers in the household
  #3 (permalink)
Old 01-22-2008, 11:40 PM
gearhead351 is starting off with a positive reputation.
Quote:
what kind of power are you looking for? engines can be built for all around performance or just high end.
I run roller rockers. Honestly they dont give you much power. But I wind my motor pretty high, so theres nothing wrong with a little more valve train stability.
also how much are you willing to spend?
__________________
"Speed costs money, How fast do you wanna go?"
"rumor is you could F**K up an iron ball with a rubber hammer"
  #4 (permalink)
Old 01-23-2008, 08:39 AM
Just want decent bottom end power to move the truck. Money is not too much an issue. Dont want to go to a 460, or a 5.4.It is a toy more or less not a high rpm mudder
  #5 (permalink)
Old 01-23-2008, 10:10 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
What year is the vehicle and motor? The 351C was never offered in trucks, cars only, so unless this has been swapped in you don't have a 351C. If you did have a "C" you probably wouldn't be looking for more power, they were 400hp motors in factory trim.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's, FRPP Mass Air, TweecerRT 282HP
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #6 (permalink)
Old 01-23-2008, 10:43 AM
Sorry, 351M 78 Bronco, pollution motor, heavy truck.
  #7 (permalink)
Old 01-23-2008, 10:48 AM
Conanski's Avatar
That's more like it. All the usual things work, upgrade the cam and exhaust and you'll pretty much have your power, though a 4bbl carb and intake will help as well. Compression on these smog motors was pretty low so if you're doing a complete rebuild try to get pistons to bump it up into the 9:1 range.
__________________
Paul O
  #8 (permalink)
Old 01-23-2008, 11:31 AM
Already swapped to Holley Pro-Jection. 21/2 inch true duals. Planning complete rebuild with shaved heads, electric fan. Did not know if roller rockers would help. Heard stock heads flow pretty good up to 5000 rpm.
  #9 (permalink)
Old 01-23-2008, 01:59 PM
Conanski's Avatar
You can either add 1.7 rockers to get more lift out of the stock cam, or upgrade the cam. These motors have pathetic little cams, and a decent upgrade won't cost much.
__________________
Paul O
  #10 (permalink)
Old 01-23-2008, 04:27 PM
Would a RV type cam be enough for 275hp? I figure if I bring up my hp, mileage will improve, up to a point
  #11 (permalink)
Old 01-24-2008, 12:10 AM
BEWOLD is starting off with a positive reputation.
Quote:
Arent the 351M and 400 the same ratio as a cleveland 1.73?
__________________
96 F150 reg cab sbx 5.0 5spd 4x4, 3 body/ 2 susp, 35 boggers, 3.55LS, mass air, K&N drop in, stock cats no muffler. 05 FX4 screw. 68 fastback 289 lawn ornament.
  #12 (permalink)
Old 02-25-2008, 12:55 PM
whdahel's Avatar
whdahel is starting off with a positive reputation.
NOt quite! even the 70 4brl wasnt that high. however with little mods it can be put into that range
The 335 Series consisted of versions of the 351 and 400 blocks. It lasted from 1970 to 1975.
351 Cleveland
  • canted-valve cyclinder heads.
    bore and stroke of 4.00 X 3.50.
    a light weight block to beat.
    one of the most desirable V8 engines Ford had to offer.
    a two barrel or four barrel setup.
    From 1970 to 1971 the 351 boosted between 250 to 240 horsepower.
    As time progress, the 351 Cleveland saw lessor horsepower until its' demise in 1975.
    the 351 Cleveland four barrel came with dual exhausts, a higher compressions ratio, larger intake/exhaust valves and four bolt mains during the first year of production.
    the 351 Windsor, which belongs to the 90 degree V8 family and bears no resemblance or connection to the 351 Cleveland.
    351 CJ
    Introduced in the fall of 1971
    mostly of four bolt mains, however there are some with two bolt mains.
    possessed a spread bore bolt pattern cast iron manifold
    Autolite carb 4300-D
    Horsepower varied from approximately 280 during the first year of production down to 265 by 1973.
    351 Boss
    Most desirable
    only available in the 1971 Boss 351 Mustang
    Four bolt mains
    high nodular iron crankshaft
    solid lifter camshaft with screw in studs
    adjustable rockers
    an aluminum four barrel intake
    351 HO
    In 1972, Ford rolled the 351 Boss over into the 351 High Output for the new year.
    Slighltly less desirable, the 351 High Output used the spread bore bolt pattern cast iron manifold
    Autolite 4300-D.
    With a milder camshaft, the output of the 351 HO was about 275 horsepower.
    351 M and 400
    By 1975 the 351 Modified was issued with Cleveland heads
    a two barrel carb.
    hydraulic lifters.
    a cast iron intake manifold.
    a two barrel carb.
    the 351 Modified and the 400 which was introduced since 1971, are virtually identical with very few exceptions.
  • Reply With Quote
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    vB code is On
    Smilies are On
    [IMG] code is On
    HTML code is On
    Trackbacks are On
    Pingbacks are On
    Refbacks are On
    Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
    Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
