Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-22-2008, 08:01 AM
armybronco2 is starting off with a positive reputation.
Smile Just an update
Hey All!
Of course I have a question but just letting you all know I was home for R&R in the Colorado area and had a blast with my '90 B2 in the snow! The look on my son's face was priceless!
OK...my question is about a clicking noise in the front end (IFS) after playing on the trails up in the mountains. I noticed it when I was on my way down. Nothing seemed wrong with steering or anything associated with the 4wd. When I got down off the mountain and took my B2 out of 4wd the clicking went away. I got under the truck and didn't notice anything obvious wrong and again didn't notice or feel anything wrong on the way to the house. I even did the oversteer test in both directions and did not feel anything wrong.
Any comments or suggestions? Unfortunately I didn't have the time to really check things out before I had to come back accross the pond. Also, any suggestions on rebuilding or swapping a reman engine in my B2 would be greatly appreciated! I plan on doing that when I get back later this year. I want to stay with the 2.9 unless your comments/experience tell me otherwise. I don't want to have to replace my whole drivetrain because of a bigger engine and I am taking fuel prices in mind too. Also, any comments on switching to a manual trans from an A4LD or simply moving my colum shifter to the floor.
Sorry for all the questions but I don't get to get on the internet that much over here so I got to cram all I can with the time I got!!!
Thanks in advance!
Also, the 33x12.50x15 Mud tread tires I got from treadwright.com were AWESOME in the snow! I went everywhere I wanted!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-22-2008, 12:32 PM
5.0B2 is starting off with a positive reputation.
Auto or manual hubs? with those big meats you could have broken one.
__________________
1965 Falcon Ranchero hiPo 289 9"
1979 Lincoln Versailles 351W 4v
1984 BII 5.0FI 4R70W B/W 1356 d35 & 8.8/disks
1997 Explorer Sport 4.0 OHV
  #3 (permalink)
Old 01-23-2008, 10:54 PM
80351's Avatar
MD Chapter LDR
80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.
First jusr let me say Thank you for being over there
so can so this kind of stuff over here.
I have to agree with 5.0b2 in that it would allow for
a better diagnosis.
Dave
__________________
Dave MD Chapter Leader
Mid Atlantic
89 Bronco 90 BII
03 Liberty
Join the Maryland Chapter click HERE
Jeepers Cheat, Ford people are true Blue
  #4 (permalink)
Old 01-24-2008, 04:19 PM
rebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to behold
It is most likely the right hand outer UJ. It is exposed to the weather and salt and goes bad before all the others. It is easy to replace once the spindle is off. What happens is the rubber seal/grease goes on a cap and then the needle bearings rust out, which causes the tick. Your hubs are probably fine.
When pressing these UJs out, put a socket between the ears so you do not bend them if the UJ is stuck.
__________________
The Year 2008 Anno Domini -
May it bring a great year of Revelations to you.
  #5 (permalink)
Old 01-26-2008, 03:07 AM
I have Warn Manual Hubs. I put those in way back in 2004 'cause I broke the auto ones and almost had the left front tire fall off! I will check the U-joints when I get back. I appreciate the feedback! Any thoughts on the manual trans, engine swao/rebuild or moving the shifter to the floor?
Thanks!
  #6 (permalink)
Old 01-26-2008, 09:38 AM
Switching the column shifter to the floor isn't worth doing, imo.
Doing a swap to a manual is easy as plug and play. Just rob all the manual stuff from a donor including the flywheel. But, a flywheel is so cheap new, it isn't usually worth grabbing. Unless you go the 4.0 flywheel/clutch/starter for a bit more beef, then teh flywheel and starter are worth having. I would grab the manual's CPU too.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
