I would like 4-speed '51 F2 tranny info, plz - Ford Truck Enthusiasts Forums
Old 01-22-2008, 12:42 AM
rcav8or's Avatar
rcav8or rcav8or is offline
If you use it, SUPPORT IT
rcav8or is starting off with a positive reputation.
Well, I busted open the 4-speed tranny on the '51 today. Didn't look too awful bad, typical tooth wear, but nothing broke or chipped, everything slides smoothly (once I got the top shift out of reverse!). My question is, are any parts/gaskets available for these Oscars? If so, where? Don't seem to see any in the repop catalogs.
going to do the ring gear, too - the motor had a car clutch/bell housing, with a good ring gear, but the truck flywheel must have more miles. Nothing broken on it, but, quite a bit of wear, compared to the other - at $30, cheap, since I have it apart.
For good news, though, did get the tranny-mount barking prake cleaned up, and ready for new lining, when it gets here.
It's coming along, slowly, but s.s.s...well, slowly!
Thanks in advance,
R
Old 01-22-2008, 05:16 AM
55 f350's Avatar
55 f350 55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
good question roger as i'm getting ready to pop open that t-98 . haven't looked at the catalogs yet . probably be smarter to find everything first . sure wouldnt want my cuz to get it apart then no parts to finish it !!!!
Old 01-22-2008, 07:46 AM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Joblot automotive NYny
also most of the Jeep aftermarket places handle T98 parts.
Old 01-22-2008, 09:50 AM
55 f350's Avatar
kool at least i wont panic yet ! lol
Old 01-22-2008, 12:06 PM
4tl8ford's Avatar
Quote:
Ya might as well get started, it's there waiting to happen.
Old 01-22-2008, 01:05 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
There a person on uPay that sells 4 speed transmission rebuild kits. I am pretty sure they're for the truck 4 speed. They allows pop up when I do a search using 1948-1952 and Ford.
Roger,
Will this help?
Old 01-22-2008, 01:14 PM
rcav8or's Avatar
Joblot's website doesn't have anything resembling a catalog - I have to wait for one.
I'll check the ebay one.
I have the parts CD, and the shop manual...shouldn't have any problem, but if I can't get the parts, no sense in pulling it apart, just to look...
Thanks,
R
Old 01-22-2008, 02:36 PM
4tl8ford's Avatar
Old 01-22-2008, 02:49 PM
rcav8or's Avatar
Yeah, I saw that, Dick...$230. Guess that's a good price, hoping to find it cheaper.
Thanks,
Roger
Old 01-22-2008, 09:35 PM
dmptrkr dmptrkr is online now
dmptrkr is starting off with a positive reputation.
Dick, thanks for the link to drivetrain.com. Nice site, easy to navigate and an incredible inventory. I see a lot of stuff there my 350 really needs.
Roger, Is your transmission a T-98? Lucky guy if it is. I think they were only available from the factory on F-4,5,6. It would have helical (diagonal) cut gears, reverse is way right then forward, rear mounting ears face forward and probably has '98' cast into left side of the case.
More likely you have the four speed, non-syncro, spur gear tranny (T-9). Reverse is way right then back, straight cut gears, rear mount ears face to rear, 59T-7006 cast into right side of case. I have four spares for parts. One is a basket case but has real nice gears. Shoot me an email if you think you want it.
For parts and info check out www.vanpeltsales.com
Old 01-23-2008, 02:35 AM
ditz ditz is offline
ditz is starting off with a positive reputation.
You really don't want to replace the counter shaft (cluster gear-pt# 7113 ) It is quite heavy and takes 2 men and a boy to lift it in and out of the top of the case. You have to hold the gear while pushing the bearing shaft thru the case and the center hole of the gear. A real humdinger of a job. I would guess that the gear is also very expensive. The hole thru the center of the gear is drilled in a special tool. You might still be able to get parts from the Muncie Indiana Borg Warner plant. They used to ship parts from the plant in the 90's. Good luck. These are heavy duty trannys and will really take a beating.
Old 01-23-2008, 09:22 AM
4tl8ford's Avatar
T-9 - Be Careful there is a small car (Brit?) t9 5 Spd Tranny out there.
Good Ol Gear Grindin' Borg Warner T-9 Ford Truck Tranny
http://www.gearwizzard.com/product.a...Borg_Warner_T9
http://www.gearwizzard.com/productDe...roductID_E_218
Old 01-23-2008, 12:09 PM
rcav8or's Avatar
Good call, it's a T-9, by the casting numbers. I haven't found it in my book, yet, looked to me like the T-98, after someone mentioned it. Power of suggestion??
Thanks, off to look at my books...
R
Old 01-23-2008, 02:02 PM
rcav8or's Avatar
Here's some pics of my gears - sorry so dirty, haven't cleaned them up yet...
What do you all think? clean it up, slap it together, and drive, baby drive, or go ahead and tear it down?
Also, the shift lever is pretty sloppy, side to side. Can't see any obvious wear, but thinking maybe build up the side of the bottom, with welding, then grind it down to get rid of some of the slop. Doesn't appear to be in the shift linkage, but some wear on the bottom of the lever. Good idea? Bad idea? Better idea???
Thanks,
R
Old 01-23-2008, 03:44 PM
4tl8ford's Avatar
The T-9, T-98, T18, T-19 are kinda like Brothers and Sisters born 3 months apart. You look at them, scratch your head and wonder why and how. They're the same thing, only different.
As far as your Tranny, the gears I see look like they're just getting to the point that they will shift good. I would clean it up and check the clearences, end play etc. if they are OK fill it up and stick it back together, if not get that minor rebuild kit. I'm not sure how your shifter is set up, I'll have to see if I can find some detail.
Jim's ongoing starter issues. ArdWrknTrk 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 127 01-26-2015 04:41 PM
2002 Escape 3.0 Automatic Tranny gone nutty... WB4IUY Escape & Escape Hybrid 9 10-09-2014 07:00 AM
'51 - '52 transmissions alamartina 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 11-24-2013 01:12 PM
Mickey Thompson Baja MTZ roostercrows 1999 - 2003 7.3L Power Stroke Diesel 13 12-10-2009 10:35 PM
E4OD Clunk Questions 86rustbucket 1968-2013 Full Size Vans 10 08-18-2005 04:07 AM
Tags
1952, 59t, 59t7006, 7006, borg, ford, price, replacing, speed, syncro, t9, t98, transmission, truck, warner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
