Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-21-2008, 10:45 PM
poppie is starting off with a positive reputation.
MPG,semi-pickup's
was talking with a camper of mine the other day and he was wondering why a newer OTR tractor's pulling 70,000#-80,000#'s can get 5 1/2 - 6 MPG and his 2008 F450 6.4 pulling 16,000#'s get's 7.5 MPG ,or my 2002 F350 7.3 PSD pulling 13,480 #'s at the scale,20,900#'s total getting 9.5-10 MPG,how do the big boy's move that much weight on that amt of fuel????,any idea's?????.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-21-2008, 11:19 PM
ghunt's Avatar
ghunt is starting off with a positive reputation.
10 speed transmissions and 2 speed rearends maybe? Good question...
Hell, don't some of the new tractors get 8-9 mpg?
__________________
1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs, ATS upgrade, 4" exhaust w/Hooker MaxFlow, custom intake, pyrometer & boost gauge, turned up fuel
http://www.cardomain.com/ride/3055099
1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners
http://www.cardomain.com/ride/306349
  #3 (permalink)
Old 01-21-2008, 11:42 PM
texastech_diesel's Avatar
texastech_diesel is gaining momentum as a positive member of FTE.
Well once you get 80,000#s moving, that big engine can probably keep it going without really trying. Buddy of mine drives a Freighliner with a 14L engine... its only 2.33 times my displacement. Throw in 9 forward gears and you can pick a good powerband to stay in.
__________________
10-0! Wreck em Tech - Go Red Raiders
Bryan
  #4 (permalink)
Old 01-22-2008, 07:24 AM
rob_nc is gaining momentum as a positive member of FTE.
OTR engines have more torque. The same 425 hp also has 1500lb.ft. of torque. Also, the power curves are better optimized and the engine almost never revs over 1800 rpm. All of this with a low rpm cruise speed equals MPG.
  #5 (permalink)
Old 01-22-2008, 08:46 AM
the avg OTR tractor with empty trailor weigh's about what the avg P/U & 5'th wheel weigh's,add on 50,000#'s of fright to the OTR rig and something does not square,take's X amt of BTW'S to move X amt of weight,anyone from MIT on here,help us out!!!.
  #6 (permalink)
Old 01-22-2008, 09:14 AM
origcharger is gaining momentum as a positive member of FTE.
I imagine OTR trucks are optimized for the job they do, as opposed to your typical pickup truck thats setup as a compromise to try and do everything.
Hows the mileage on OTR trucks that meet the 2007 emission standards faired?
__________________
Powerstroking Seven T444Es, one VT365 and one 6.0. Also four DT466s, one DT360 and a Mercedes MBE906.
I'm doing my part to reduce food imports, control rising food costs and help feed the children, my trucks run on 100% petroleum diesel. What are you doing?
  #7 (permalink)
Old 01-22-2008, 10:12 AM
FARM69's Avatar
FARM69 is gaining momentum as a positive member of FTE.
Well, in the rig I drive usually gets about 3-4 depending on how hard you push her. The newer mercedes diesels are supposedly the best on fuel milage.
You might be able to find a little daycab with a light, light aluminum trailer to wiegh 20,000 empty (or a flatbed).
Orig, I think you hit it on the nail. OTR have the gearing and the powerband right where you need it. Out of our two trucks, both Pete's, one is definitely the highway king and the other is the backroad overweight pulling machine.
I can't help ya with the emission question. I don't know of anyone that has purchased a brand new truck.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / 10 K / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water Temp]
4" Straight / EBPV Exhaust Brake / 6637 / CCV / 203 Stat / HX50 (19cm) is being mounted!!
  #8 (permalink)
Old 01-22-2008, 01:47 PM
ghunt's Avatar
Speaking of square, that's another thing...a truck with a box trailer is like a brick moving at 70 mph. Has to be a lot of drag on that thing.
__________________
  #9 (permalink)
Old 01-22-2008, 04:27 PM
tjc transport's Avatar
find me if you can!!!
tjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant future
my mack running loaded at 80,000 all the time will only get 2 1/2 to 3 mpg.
but if i go out and drive around for 10 hours empty(23,480lbs) with the cruise set at 65mph, it will get almost 11 mpg.
__________________
Join me in the New Jersey Chapter, CLICK HERE!
NEW JERSEY CHAPTER LEADER
Tom
65 falcon 2dr h/t hot 289/C4
66 7 litre 4 speed convertible
79 F250 4X4 plow rig 351M C6
88 superduty diesel 4X4 C6 and banks turbo
99 crown vic P71 interceptor
02 F250 superduty diesel 4X4 stretchcab shortbox, all better now!!
  #10 (permalink)
Old 01-22-2008, 04:36 PM
dascro is starting off with a positive reputation.
Do you have the MP8? I thought they got better MPG than that when loaded....
  #11 (permalink)
Old 01-22-2008, 04:46 PM
2004 RD686 with a 400hp renault/mack pos diesel, an eaton fuller 8LL trans, 44k rear suspension, 12.00X24.5 rubber on the rear, with floaters on front and the air tag. . not sure on the gear ratio off the top of my head, but top speed is 74mph.
i carry 120 gallons of fuel, and the worst i ever got was the day i ran loaded for 480 miles, and used 198 gallons. the bast i ever got was coming home from Port Jarvis N.Y.
i filled up at the end of the shift, and went into the hotel for some shut eye. after i got some sleep, i drove home. 100 miles, and only took 9 gallons.
__________________
Tom
  #12 (permalink)
Old 01-23-2008, 07:51 AM
Sounds like you've got 4.64 rears. What do you haul that requires this heavy of a truck?
  #13 (permalink)
Old 01-23-2008, 08:36 AM
................. 2 1/2-3 mpg, Is that all city/urban driving?,when I was hauling stone for sewer job's in a day cab Mack @ 70,-75,000 #'s the ole girl got 5-5 1/2 running I- 90 from the pit at beverly & I-90@ Elgin Il to the Schumberg I-90 & 53 area,aprox 40 mile's or so and that was with ,at that time,a 28 year old hunk-o- junk with a 237 and a 5 speed,the ole girl was flat wore out!!!!!!!.
  #14 (permalink)
Old 01-23-2008, 04:06 PM
SANDDEMON08's Avatar
FORD POWERSTROKE JUNKY
SANDDEMON08 has a good reputation on FTE.SANDDEMON08 has a good reputation on FTE.
Quote:
Your F-450 SD proably runs 2400 to 2700 rpm running down the road 70-75, the over the road trucks are only running 1600 to 1800 depending on gearing. You tach out at 3400 +or - with your 6.4 they tach out at 2100-2200 + or - . Just my .02
__________________
Got beer ? 498HP 965
2008 F350 SD CC FX4 ON 20's, 6.4 PSD,TORQ-SHIFT,3.73 REARS, NAV, BLACK LEATHER SEATS,DASH DAQ GAUGES, AFE STAGE II INTAKE,SPEARCO INTERCOOLER,CUSTOM TUNING, SEIC MOD,AMP REASEARCH STEPS, LINE-X SPRAY IN BED LINER, T-REX BILLET SIDE VENTS.
  #15 (permalink)
Old 01-23-2008, 04:19 PM
mudmaker's Avatar
mudmaker has a good reputation on FTE.mudmaker has a good reputation on FTE.
The new emission standards have killed the mileage on OTR trucks as well.
__________________
Marc
2002 F350 SRW CC LB 4X4
2002 Excursion Limited 4X4
PAA #20
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
