Fan speed sensor - Ford Truck Enthusiasts Forums
Fan speed sensor
Old 01-21-2008, 10:42 PM
run6.0run's Avatar
run6.0run run6.0run is offline
run6.0run is a splendid one to beholdrun6.0run is a splendid one to beholdrun6.0run is a splendid one to beholdrun6.0run is a splendid one to beholdrun6.0run is a splendid one to beholdrun6.0run is a splendid one to beholdrun6.0run is a splendid one to beholdrun6.0run is a splendid one to behold
Fan speed sensor
Anybody know where this is? Keep getting a code.
2006 f350 6.0 259k
Old 01-22-2008, 07:51 AM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.
in the fan clutch.
Old 01-23-2008, 01:14 AM
run6.0run's Avatar
should the fan be fairly easy to spin when cold? I thought they were pretty stiff. Mine doesnt seem like it moves as much air at a idle. If I remember right then it would make my hair blow around when I would put my head where I could see the blades(that post is just asking for a joke). Also when should it kick on. Mine used to kick on at 218 but now I cant even tell you with any consistancy when it does.
So if the sensor is in the fan then chances are with the other issues I am having then replacing the fan clutch should eliminate the fan sensor code. THANKS
6.0 crankshaft run6.0run WTB - Parts & other 0 09-15-2013 06:51 PM
2006 6.0 runs rough jeter 6.0L Power Stroke Diesel 5 01-06-2013 09:25 PM
derale trans cooler vs. 6.0 trans cooler john8403 1999 - 2003 7.3L Power Stroke Diesel 5 10-07-2010 11:11 AM
Nxd On 6.0 Z-MAN 6.0L Power Stroke Diesel 1 02-27-2006 07:43 PM
anybody running edge evolution on 6.0 pierre35 Manitoba / Saskatchewan Chapter 4 12-20-2005 09:22 PM
Tags
04, 60, 60l, fan, ford, sensor, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
