Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 01-21-2008, 09:41 PM
timsheehan is starting off with a positive reputation.
Brake Pull to the Left
I have a 2000 Excursion 4WD V-10 with 151,000 miles. It has always had problems with pulling and vibration when braking. Usually new pads and a turned rotors would do the trick but the problem reappeared when the pads were half worn. About six months ago it started pulling hard to the left when braking. I decided to change out the calipers and brake lines, new pads, turn the rotors and put this problem to bed. Within weeks of this work the problem reappears. I talk to the Ford shop and he suggests I may have a tempered rotor from overheating and try swapping rotors and pads and see what happens. I switch them and the vehicle either stops good and straight or pulls to the right. I put on new rotors and pads both sides. I noticed a tear in a cup rubber pad on the right caliper so while it's under warranty I switch it out too. Bleed the brakes, take for a drive and it brakes like new. Car sits for an hour then we go to the movies, brakes fine, come out the movies and on the drive home it starts the hard pull to the left again when brakes are applied. I had ball joints replaced about a year ago and had grease-ables installed and I grease them. I need your help, please advise....TIM
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-22-2008, 07:30 AM
DSMMH is starting off with a positive reputation.
It sounds like you have debris in one of the brake lines. I just fixed a similar problem on my T-Bird SC. My SC pulled hard to the left on initial braking but then would brake with a little pull on subsequent braking. I knew it was debris because I have fixed this problem before and I had just changed the Master Cylinder when this problem started. Doing that will jar debris loose in a brake system. Also, brake fluid has an afinity for moisture and subsequent brake line rust. So Friday I removed the right front wheel and started removing brake line parts. First part back from the hose was the ABS pressure sensor. I removed the sensor and there it was. Debris in the sensor. Cleaned the sensor with HP air and now it brakes great.
I would suggest that you remove the line that goes into the non caliper end of the brake hose and have someone push on the brake to do a flush. I would catch the fluid in a clean jar and check to see if any debris comes out.
DSMMH
__________________
04 EXCURSION LTD: 4X4, 6.0L PSD, JUICE w/Tude, Jobe Intake, Elbow Upgrade, ZOODAD, MBRP T-Back, Bilstiens, Hawks, Cryos, Prodigy, Remote Starter, Red OPTIMAs, 30MM Sway Bar, WAAG FB Guard, Dual Steering Stabilizers, Fuel Cross Over Line, PML Tranny Pan, Coolant Filter, 160 AMP Alt Upgrade and RP Synthetics.
  #3 (permalink)
Old 05-15-2008, 05:59 PM
RDJ184's Avatar
RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.
Did you check tie rod ends
__________________
JOIN NEW MEXICO CHAPTER HERE!
RANDY 06 6.0 4X4
  #4 (permalink)
Old 05-15-2008, 09:02 PM
danny2001xlt is starting off with a positive reputation.
Exclamation brakes pull 2 the left
I had the same exact problem 2 days ago and it was the caliper guides or you may called the caliper pins ect ect . They are the bolts that you mount the calipers on , you have to lubricate those every once in a while or they get rusty and thae caliper wont slide in and out so you only are braking on 1 side and it pull like a b-----. hope this helps .
  #5 (permalink)
Old 05-15-2008, 10:05 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
