12 volt sending units
i am helping to rebuild a 1950 ford pickup.it has a chev 350 in it. we want to use the original dash and gages.it will have a 12 volt system in it.i know i have to put a dash gage current voltage reducer in to use the 6 volt gages. what i dont know is if i can use the 12 volt sending units from the chev engine.has anyone had any experience with this? also, can i use a 12 volt gas gage sending unit with this set up? i will appreciate any help i can get on this.
on
1 Post
Hi,
I converted my 51 Ford Truck to 12 Volt and used the original gauges. But, gauges and sending units are usually matched so you need to use the original sending units for the gauges, not the chevy senders. Eventually, I converted my Oil and Temp gauges to mechanical using new gauge insides and the original faces and cases (except the gas gauge where i used the voltage reducer) It worked out great. If you have an induction loop on the back of your amp gauge, you don't need to change that. The gauge will pick up the flow whether it's 6 or 12 volt. I have a one wire alternator (no firewall regulator) and ran the output wire through the original amp gauge and it works fine. I have pictures of building up the new mechanical gauges. When I figure out how to do it, I'll build up a gallery for folks to look at.
On a 51 panel truck project this past summer I used the stock gauges and used the runtz voltage reducer that mounts on the back of the gauge to drop from 12v to 6 v. I then used the both the oil and water sending units from the flathead v8. Installing the oil sender was easy but the water sending unit is rather large so I was able to use a 3/4 inch steel pipe tee and screwed the sender into one end and plumbed this into the manifold to water pump bypass hose. This allowed coolant to circulate around the sending unit. Need to solder a ground wire onto the steel tee to complete the circuit but worked great. The engine in this truck was a dodge slant 6.
rustoleum82
03-07-2015 04:57 PM
Crewcab Turbo
02-09-2015 10:57 AM
bert cook
11-10-2014 02:49 PM
tractormanbill
08-05-2014 01:25 PM
tractormanbill
07-30-2014 03:34 PM
