Reverse gear hesitation... - Ford Truck Enthusiasts Forums
Old 01-21-2008, 05:36 PM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
I have noticed, in the last week or two, a hesitation of my truck going into reverse gear. When I put it in R, there is a delay of a second or two before I feel the drivetrain lockup...anyone else experience that? I used to put it in R and it was immediate drivetrain engagement. The truck drives just fine, tranny shifts normal and no delay going into Drive. No rattles, low tranny temperatures...last fluid flush less than a year ago (about 10K miles)...external tranny filter.
Old 01-21-2008, 05:51 PM
Pocket Pocket is offline
Pocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputation
Mine has always had a hesitation. The BTS does it less, but there's still a slight hesitation there.
Old 01-21-2008, 11:02 PM
Mike Norwood's Avatar
Mike Norwood Mike Norwood is offline
Mike Norwood is gaining momentum as a positive member of FTE.
just bought a 2001 f-250 and had the same hesitation about going into reverse and then the reverse went out. dealer is replacing the transmission now(within thirty days so lemon law applies)
Old 01-21-2008, 11:08 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
I've always had at least a second, maybe two's, hesitation, and consider it normal. I always wait until I feel engagement before adding ANY power.
Pop
Old 01-21-2008, 11:11 PM
i've heard about that. simply relating my personal experience. had no hesitation out of my '99 f-350 with the same tranny. also the reverse never goofed up until it had been under a load for about half hour( I pull a 6,000lb utility trailer)
Old 01-21-2008, 11:25 PM
That_Guy's Avatar
That_Guy That_Guy is offline
That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.That_Guy has a great reputation on FTE.
Mine did that, just flushed the tranny and changed the filter and that fixed everything, you might want to check the the fluid level though.
Old 01-22-2008, 07:48 AM
RogueSpear2023's Avatar
RogueSpear2023 RogueSpear2023 is offline
RogueSpear2023 is starting off with a positive reputation.
I think they all have at least a second of hesitation due to the torque converter locking up.
Old 01-22-2008, 08:29 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Well, if it is a change from previous behavior, something happened.
Old 01-22-2008, 09:24 AM
nlemerise's Avatar
Quote:
That is my feeling too Dan...something has changed...the delay is definitely longer now in going into reverse. I am going to drain the tranny (rather than flush it this time) so I can pull the pan and look inside a bit...I was hoping that someone would say "you need to tighten the thigamajigger to 25 in-lb and check the parallax of the muffler bearings" and it will be fixed . No such luck ...I have a feeling that a trip to John Wood Transmission is in order before fire season starts, if changing the fluid has no positive effect. Thanks guys for the input...much appreciated.
Old 01-23-2008, 04:55 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
Neal,
I found this earlier when I was searching Dieselmanns technical bulletins
Reverse Engagement Stall:
Some trucks with the 4R100 transmission may stall upon shifting into reverse. This is usually caused by the torque converter clutch being engaged at idle. Engineering is investigating. Broadcast Message 1222.
If this condition occurs under cold temperatures only, it may be due to increased viscosity of the ATF. Ford is recommending changing the ATF to synthetic in this case. Broadcast Message 1435.
I know yours doesn't stall but it may just be a fluid thing.
Old 01-23-2008, 05:20 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
Quote:
Originally Posted by bdrummonds
Neal,
mine stalled in reverse for first few winters I owned it
now since rebuild and new torque it has the hesitation in reverse but no stall
Old 01-23-2008, 07:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
The torque converter does not lock up in reverse. Ever! It also never locks when the truck is not moving.
Old 01-24-2008, 10:02 AM
nlemerise's Avatar
Neal,
I'm going to flush and change to synthetic as soon as Mr Winter gives up his grip on northern Nevada OR when I go to my southern New Mexico digs next month . I've got nothing to lose by trying that as PM on the tranny...but after corresponding with Mark K I am budgeting for a John Wood rebuild in the future.
Old 01-24-2008, 03:40 PM
dieseloholic's Avatar
dieseloholic dieseloholic is offline
dieseloholic is starting off with a positive reputation.
My original trans had a small delay, but never seemed to have a problem (with reverse). Since having it rebuilt and upgraded there is no delay.
Old 01-24-2008, 06:24 PM
Heff-7.3PSD Heff-7.3PSD is offline
Heff-7.3PSD is starting off with a positive reputation.
I noticed that my truck only did it when the air temp was in the 30's or lower. Once the truck warmed up I did not notice it. I would fire up my truck to get something else out of the garage and put it in reverse and nothing for about 2 to 5 seconds. I took it to the dealer and they could not find anything wrong.
1993 F150 hard/delayed shift questions focalized 1987 - 1996 F150 & Larger F-Series Trucks 8 02-09-2015 06:44 AM
Slight delay going into reverse from drive stimm32 1999 to 2016 Super Duty 4 06-23-2014 11:36 PM
TROUBLE SHOOT MY 5R110, PLEASE StanleyZ 6.4L Power Stroke Diesel 17 07-02-2013 06:02 PM
Trouble shoot my 5R110, please!!! StanleyZ Clutch, Transmission, Differential, Axle & Transfer Case 6 06-26-2013 04:31 PM
Delay when shifting into reverse lude98r 1999 to 2016 Super Duty 2 01-16-2013 02:38 PM
Tags
2000, 2001, 73, automatic, delay, delayed, engagement, explorer, f250, f350, ford, hesitates, hesitation, reverse, shifting, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
