Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Alberta Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Hallworth
  #1 (permalink)
Old 01-21-2008, 12:47 PM
yellow truck's Avatar
yellow truck yellow truck is offline
1969 Ford F-100
yellow truck is starting off with a positive reputation.
Any vintage truck specialists in Alberta?
I have 69 F100 4WD with a 360, manual brakes, and a fairly lame power assist steering. I the 360 rebuilt by a guy who turned out to be a liar and an idiot, so it took longer and cost more than it should have, but with a mild cam, and Edelbrock intake a 650 CFM 4v it is now running fairly well.
The front end is a little different because of the power assist - the tie rod is reversed (long end on the passenger side) and it has an extra hole in it to attach the power assist.
I am having a pretty deep restoration done on the body right now, but while the guy is a craftsman and does beatiful work (Ronnies Rides in Carstairs), he doesn't do mechanical. I'd like to find someone that can do some work on the front end (switch to power disk brakes, proper power steering, and some suspension improvements) who has experience with older trucks.
Any suggestions?
  #2 (permalink)
Old 01-23-2008, 02:42 PM
mcdonaldm mcdonaldm is offline
Garage is empty, add now
mcdonaldm is gaining momentum as a positive member of FTE.
try some of the local 4 x 4 shops. they should be able to do those modifictions pretty easily. stick to the ones that are more into the true off road stuff then the ones that sell bolt on doo-dads and appearence packages for the posers.
rgds
Mike
  #3 (permalink)
Old 02-26-2008, 08:58 PM
floyd67 floyd67 is offline
floyd67 is starting off with a positive reputation.
try blue oval restorations PAUL 5196867 he is west of airdrie
  #4 (permalink)
Old 02-27-2008, 09:01 AM
1969 Ford F-100
Thanks Floyd, I'll get in touch with him when I get home (I'm hiding in Arizona till spring break up).
Tags
airdrie, alberta, big, block, blue, calgary, ford, fors, oval, restorations, specialist, specialists, truck, trucks, vintage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
