Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-21-2008, 10:23 AM
Buddly Buddly is offline
Buddly is starting off with a positive reputation.
OK, ignorant on the 3.0L V6
So........ does it have a timing belt or chain ?
This is a FI 3.0L w/ 286,000 miles in a '93 ranger extended cab.
Running fine for 1 minute then died a quick quiet death. if the belt/chain is busted will it show as no rotation on the distributer ?
Like I said, this is new territory for me.
  #2 (permalink)
Old 01-21-2008, 10:49 AM
merlynr's Avatar
merlynr merlynr is offline
merlynr is starting off with a positive reputation.
Yes it has a timing chain and if it is broken the dist will not turn.
__________________
97 F250 4X4 7.5
71 F350 dump 360
99 Explr XLS 4.0
07 Edge SEL+ fwd
73 Mustang cpe
71 Mustang cpe
  #3 (permalink)
Old 01-21-2008, 11:01 AM
Thanks
I'll check it out after work.
If the distributor IS turning does that indicate a coil or distributor pickup problem ?
There is NO spark. I checked the coil and find 1900 ohms on the secondary. Haven't checked the primary.
The nature of the failure is troubling. At 4 degrees here yesterday morning It fired right up and ran for about a minute. Then, without even a cough, it stopped. Like I shut the key off or something.
  #4 (permalink)
Old 01-22-2008, 09:36 AM
Thanks again. Turned out to be the ignition module mounted behind the battery ( and a sh** load of cables) on the radiator mount.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
