worn distributor gear!
Old 02-25-2002, 05:24 PM
schweg2's Avatar
schweg2
schweg2 is offline
Post worn distributor gear!
Anybody have problems wearing out dist gears on a 429/460
I have a comp extreme 4x4 cam, MSD dist. I tried a stock
dist with the same result, moved the gear up and down on the shaft which didn't seem to help. The oil pump seems to turn easily (no binding). Any ideas?
Old 02-25-2002, 05:39 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
280,000 Miles and going strong.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old 02-25-2002, 06:24 PM
83f2504x4's Avatar
83f2504x4
83f2504x4 is offline
Just my thoughts on the problem...leave one of the worn gears on there for awhile and see if it continues to get worse. You would think that once it wears itself in, it would be fine.
Old 02-25-2002, 07:51 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
There was talk on here a little while ago about HAVING to use a brass distributor gear on certain cams.
Maybe You have one of theose.
w/Explorer Pkge.
84 Volvo DL Wagon
Old 03-20-2002, 04:41 AM
8 Lugs's Avatar
8 Lugs
8 Lugs is offline
I hope you caught this before it destroyed the cam on a fresh motor! I didn't. After tear down, bearing and cam replacement, sending distributor to MSD for gear hardness testing, and talking to every manufacturer I still had the problem of distributor gear wear after 30 minutes cam break in and tuning. (this is a comp cams 280/ msd pro billet combo) I have another 460 with comp cams 270/ mallory unilite/ jacobs computer ignition combo with approx. 50,000 miles on it. Removing the distributor I found no visible wear! I ordered a Mallory gear #29420 from summit/ installed it on the msd dist. No problem ever since Good luck!
Old 03-21-2002, 12:50 AM
TonyG's Avatar
TonyG
TonyG is offline
I was just doing some searching the web on for info on roller cams for the 460. The one website (crane I think) mentioned haveing to use a brass gear and a heavy duty washer in there somewhere for a certain cam. They offer both. It's something that the people at Crane might be able to help you with also and it might be worth giving them a call.
Tony
Old 03-21-2002, 02:51 AM
pro3qtr's Avatar
pro3qtr
pro3qtr is offline
