Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #196 (permalink)
Old 04-01-2008, 09:35 PM
bgalaxy67's Avatar
bgalaxy67 is starting off with a positive reputation.
Quote:
Originally Posted by Truckin4life View Post
yea, mine were real dark. BLACK dark, and still smelled horribly like 4 days later.
Pics of carnage are always fun, unless its your carnage.
I knew it was coming so it wasn't a big deal.
It's when you turn on the system and hear nothing..... thats tough to take.
__________________
If the listening level is too loud, promptly inform the driver, so he may pull over, and let you out
My Excursion
Wife's 250
Sponsored Links
To remove this ad, register today!
  #197 (permalink)
Old 04-02-2008, 07:18 PM
Fordinator is starting off with a positive reputation.
Yeah,,lookin good.Speaking of batteries and charge,,etc.I'm waitin on My Audiobahn A1500 HCT amp to come,,in reveiwing some things I seeing that its a power comsuming piece of equipment,any suggestions,,anyone,on what I should add to keep the charge proper??I've looked at caps but not sore what farad to get,,I don't really want to add another battery unless I have to..
  #198 (permalink)
Old 04-02-2008, 11:01 PM
Truckin4life has a great reputation on FTE.Truckin4life has a great reputation on FTE.Truckin4life has a great reputation on FTE.Truckin4life has a great reputation on FTE.
general rule of thumb is half a farad for every 500 watts i believe. so if your amp is 1500 watts then a 1.5 or lager cap will do. I would suggest an upgrade on the big 3 first. Do a search and im sure it will come up.
__________________
Don
I like bacon.
95. f250 4X4. "stock" 5.8l mated to a zf 5speed.
37" good years and some fender trimmin.
Life is short. Play hard!
  #199 (permalink)
Old 04-02-2008, 11:50 PM
bgalaxy67's Avatar
Quote:
Caps have their place but are seldom used right.
If you have a quick flickering of power loss, then I would suggest a cap. However if there is a lack of continous power, then you need to look at the charging system as a whole.
Wire size
grounding
battery
these 3 things need to be addressed to insure you have enough power of the amp.
Wiring. Anything less the 1/0 wire these days is just asking for trouble
Grounding, Look up the "Big 3" it's a must in my book. but also don't over look a good ground at the amp. If at all possible, run a ground from the amp to the battery. yes it's more money but will make all the difference.
When you address the 1st two then add batteries. The alt will be good enough to charge a couple of batteries, Yes it will strain the alt and make it work harder and yeas it will take longer to charge.
After you do all the above then look for a bigger alt.
__________________
My Excursion
Wife's 250
  #200 (permalink)
Old 04-03-2008, 07:36 PM
I did come across the big 3 setup last night,,going to do that this weekend,My 1000watt fusion amp I've been running never really flickered,My truck is an 04 SD F250 crew cab,,not sure what the alt rates for but will look into that also.Thought the cap would just add to the look though. I'm really not sure what my son plans on wiring at,I think he said the subs are 800watts RMS and he's going to put 1000 to them.Just want to make sure ,,cause he has a habit of blowing his stuff up,lol.I like to show my truck,,with a little muddin here and there,,but I like good rockin,,loud system,,that'll turn heads..
  #201 (permalink)
Old 04-03-2008, 11:00 PM
i think bgalaxy pretty much nailed it right on the head. no need to repeat what he said, keep us updated if our suggestions fix your problem or not.
Later,
Don
__________________
Don
I like bacon.
  #202 (permalink)
Old 04-04-2008, 11:02 PM
bgalaxy67's Avatar
I spent most of the day cleaning the baskets for the re-cones. I'm glad thats over.
I started on some glow tonight.
I used a j-Track for a mirror to hold the LEDs in place.
Then squirted some clear silicone to hold them in.
__________________
My Excursion
Wife's 250
  #203 (permalink)
Old 04-05-2008, 04:11 AM
johnperdeye is starting off with a positive reputation.
looking good man what kinda prices did mike give u on that amp
__________________
04 f250 cc sb fx4 6.0 bullydog triple downloader, leveling kit and more to come
  #204 (permalink)
Old 04-05-2008, 10:07 AM
bgalaxy67's Avatar
Quote:
It wasn't quite an arm and a leg but close
Mike a good guy and was very helpful in my amp selection process.
__________________
My Excursion
Wife's 250
  #205 (permalink)
Old 04-05-2008, 06:55 PM
have u clamped it yet to see how close 10,000 its doing...yea im talking to mike about there maxximus subs for my van
__________________
  #206 (permalink)
Old 04-05-2008, 07:35 PM
bgalaxy67's Avatar
No.
In the 5 min that the subs were playing, I didn't have time to do any testing to it before they gave up.
I hope to get some testing done before I'm back in the lanes. But I might be short on time. My Ear-O-Meter tells me that it is close to what the Excursion was DB wise. 49-51, maybe a tick more with less people in the truck, seat forward and on the right songs. I'll know for sure later this month with a USACI show and DB Drag all in the same weekend.
Too bad we can't get Maxxsonics to bust out with the 18.
I think the DC's will fit the bill nicely
__________________
My Excursion
Wife's 250
  #207 (permalink)
Old 04-05-2008, 08:44 PM
cangim's Avatar
cangim is gaining momentum as a positive member of FTE.
I finally made it through all the reading on this. Very killer system you've go going on Bgalaxy67. Looking very nice. Do you have any finished pics of the door panels? Didn't see if you did both front and rear doors.
__________________
Wishin I was still camping somewhere....
-Mike
  #208 (permalink)
Old 04-05-2008, 08:53 PM
bgalaxy67's Avatar
Quote:
Thanks!
I don't.
But I'll get some soon. I haven't started on the grill covers yet. Plenty of time Next show is on the 26th and I'm in Atlanta the weekend before. I guess I better get back to work.
__________________
My Excursion
Wife's 250
  #209 (permalink)
Old 04-06-2008, 08:31 PM
verumlike's Avatar
Über Üser
verumlike is gaining momentum as a positive member of FTE.verumlike is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by bgalaxy67 View Post
Thanks!
I don't.
Need a job ? let me know =-P
__________________
GRIFF
F350 CC LB
20''Custom Lift, Big Hoss Prog., 52''Military's, 20''Mazzi Hulks, 2.5 King Piggy Backs, Eclipse Indash DVD, Memphis all around, Atlas Springs, Amp Steps, Custom Interior, 07' Front End, 08' Rear End, Viper Alarm, MBRP 7'' Turbo Back, K&N Intake .etc.
  #210 (permalink)
Old 04-06-2008, 10:03 PM
bgalaxy67's Avatar
Quote:
I'm always looking for a hustle
__________________
My Excursion
Wife's 250
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
