i use multiple runs in my van its hard to find anybody now a days that makes anything bigger than 1/0 cause the cost of copper is going up everyday.....
__________________
04 f250 cc sb fx4 6.0 bullydog triple downloader, leveling kit and more to come
I hear ya on that.
Her truck should be good on the 4 runs of 4/0. She won't be pulling as much amperage as my Excursion.
__________________
If the listening level is too loud, promptly inform the driver, so he may pull over, and let you out
depends on ur current draw......and length of wire.....i pull about 3200 amps of current draw in my van i have 8 run of 1/0 from alternators to batteres in back and i need more
__________________
Hers won't have more then 2000amps of draw. It's still a daily driver.
__________________
Slow going tonight. I got the Video Bypass switch working and got both door pods moving along.
Here's the pass side all glassed up
And here's the drivers side with a coat of filler on it. They will be cover in vinyl so I don't have a whole lot to do with them, just a few spots to smooth out.
__________________
coming along qutie nicely, patiently wating to see the finished product, looks real nice all around. I never thought about steeping up to welding cable, good idea though.
Later,
Don
__________________
Don
Stg's Minions: 12 volt specialist
1995 f-250 ext. cab, lb. 4x4, 5.8 5 speed. Performance mods, and a heavy foot.
Quote:
Originally Posted by STGFordCrazy04
X2 and hes not talking about truck nuts
Welcome to the Minions house.....Giving correct answers since 2007.
Later,
Don
Thanks!
I would be further along if it wasn't so cold and rainy these last few weeks.
__________________
bgalaxy67,
Been following your progress Looks awesome.
I just got finished tonight tearing out my interior to install a new system. I am no expert by any means. With that being said can you tell me how you are tieing in your speakers to the amps. I am installing one and need to know if I should run all new wires to the speakers or just run wire to the harness behind the stereo.
Any tips or suggestions would be greatly appreciated on any part of the install.
Thanks
bgalaxy67,
Thanks
Thanks Bro!
Honestly for the most part I run the wires back to the harness. I really don't like to dig into the door boots unless I have to. I feel the wire in the doors is plenty for a standard 4 CH amp.
__________________
Thanks for the info.
Keep up the good work and keep the pixs coming!!!!
is that a selenium extreme sub
__________________
