Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-20-2008, 09:38 PM
ebryant is starting off with a positive reputation.
Cool no spark
wired in accel 250 by the numbers, still no go checked dist. replaced stator,pick-up,cap,rotor checked replaced ing module. checked 6 pin at module no voltage didn't see any bed wires could it be ecm?????
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-21-2008, 01:09 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
No, the ignition system is designed to function without the PCM. Without the PCM there will be no spark advance, but it will still spark. I would suspect that the PIP signal is not getting to the module. Look for corroded connectors, broken wires. Verify that the new pickup is generating a signal when the engine is cranked. In fact, verify that the distributor is spinning when the engine is cranked. I have seen the pins go bad in the module connector before, so don't forget to check that.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
