This is not for a Ford truck but rather a Ford tractor. How does one go about removing wax from a diesel system? My tractor sat for a while after my friend used it last. He put biodiesel in it and it waxed up the filter and now I think it is in my injectors and pump? Do I have to take everthing apart to clean it up or is there something I can put in the fuel and let it circulate to clean it up? Rightnow it is only marginally running. It is a model 2310 3 cycl n/a diesel. I have aready drained the tank and replaced filter. Under full throttle it will not get above 1K rpms. Not getting any fuel. I need to use it soon b/c I have to grade out the backyard for a building. Any help greatly appreciated. Thanks.
BTW it is a non glow plug motor. It starts on its compression alone. And it is a pain to even get it to start right now.
__________________ Member of South Carolina Mudboggers Association
94 Ranger 2wd sittin on 33x12.50's.
93 Ranger 4wd sittin on 39's.
Proud owner of 2008 F-150 4X4!!!!!!! Needs Boggers and Lincoln Lockers
I hate Toyotas.
I've never had my truck wax-up on me like you described. I don't know if there is a "de-waxer" that can be poured into the tank to clean out the fuel system.
I think you're gonna hafta take her apart and clean. Hopefully, someone here will chime in with good news. If not, have your friend help.
__________________
Craig "IDMooseMan" Peters
1997 F-350 XLT 4x4 CC LB E4OD 4.10:1
FPR Shimmed to 70 PSI, 6637 Upgrade, ICP Resistance Mod, DiamondEye 3" Downpipe and 4" Exhaust
USAF SSgt 1983 - 1992
NAHC Life Member
1991 Wilderness 24M
My friend is a retard. Putting biodiesel in a 30 yr old tractor that has always run on #2 diesel.
I was kinda thinking the same thing, but didn't want to say it out loud.
Your friend should be cleaning out the wax while you offer encouragement from the rocking chair. His ice-water will be near you. While waiting for him to finish cleaning, you drain the required amount of your favorite beverage.
__________________
NAHC Life Member
1991 Wilderness 24M
The wax needs to reach `84 degrees to begin to dissolve and become liquid again.
__________________
1976 F-250 Camper Special - does not run
1977 F-150 Northland Edition - does not run
2002 F-350 Powerstroke
1996 Ranger 2wd 4cyl manual - daily driver
Diamond-T 5-ton truck - does not run (May recieve a DT466 in the future)
You have to get the tractor inside and warmed up, drain everything you can. Add fresh fuel and fuel filters, then let it run. The new fuel will flush out the injection and pass any wax.
