Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-20-2008, 07:52 PM
DROPDOUBT is starting off with a positive reputation.
cranks but no start
i have a 90 ranger 2.9l it cranks but none of the relays get power the coil dosnt spark and feul pump dosent turn on. how do i check power to the ecu?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-20-2008, 11:01 PM
mrshorty is starting off with a positive reputation.
Does the CEL come on with the key on engine off? The CEL is supposed to come on before starting the engine to indicate that the ECU has power.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #3 (permalink)
Old 01-20-2008, 11:28 PM
what is the CEL?
  #4 (permalink)
Old 01-20-2008, 11:29 PM
we have no dash no gauges or ac or heater the cab is totaly gutted and fully caged.
  #5 (permalink)
Old 01-21-2008, 10:16 AM
CEL=Check Engine Light. If you've taken out the dash, then you've probably taken out the CEL. What else have you taken out? Did you lose the wire that goes from the ignition switch to the EEC relay? STandard way to check power to the ECU is to get a wiring diagram, locate the ECU's power wires (I believe there are three at the ECU), and see if they have power using a voltmeter.
__________________
  #6 (permalink)
Old 01-21-2008, 02:35 PM
rdelp is starting off with a positive reputation.
I had a similar problem on my 1999 ranger... it was the Crank Shaft position indicator. $15 part and 10 mins to change.
ROb D.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
