'09 3v V10
'09 3v V10
I was reading one of those brochures you can get at an auto dealership the other day and it said in there that the new V10 "when properly equipped" is capable of out pulling the competitors diesel engines.
As much as I love the V10 even I am having a hard time believing this one. I mean the 6.4 (from what I have read) doesnt even out pull the Dmax or CTD. How do the guys for FoMoCo advertising justify saying such bold things in their brochures?
Originally Posted by 93RangerXL4x2
The Ford Diesel out pulls CTD and DMX. easily due to ford being a tougher truck.
Anyway, there was a magazine test not too long ago where the gasser V10 was faster unloaded or loaded then the Diesels, and the 6.4 PSd was the weakest of the diesels.
This might be what everyone is looking for as far as articles.
http://www.pickuptruck.com/html/2007...shootout1.html
This tested acceleration of all the players in the 3/4 and 1 ton market. All the biggest gas engines and all diesels. The Duramax equipped GM 1 ton was pretty handily the winner over everything in the test.
Of the gas engines the 6.0L GM combined with the 6L80E 6 speed auto was fastest even loaded with a 10,500lb trailer on level ground, and was in second place in elapsed time up a 7% grade. Interestingly if the grade was longer the GM would have ended up passing the V10 equipped Ford up the grade, as the GM was gaining speed more rapidly after the initial start. The GM topped the grade with the highest speed.
Originally Posted by ghunt
If Ford could get a decent transmission behind the V10 (since nobody tests sticks anymore), they could wipe the floor with everyone else in the gas engine segment.
Originally Posted by BigDaddy6969
On the 15% grade loaded the V10 put up a nearly identical time as the 6.4. HMMMM.... maybe the brochure wasnt BS'ing me. I love the V10.
I guess I was the only one that picked up on the truck WEIGHT.
The 6.8l is 1,240lbs heavier than the Dodge and Chevy gassers.
The 6.4l is around 1,000lbs heavier than both the Dodge and Chevy diesels.
Even with this weight DISADVANTAGE the Fords managed to match or beat the competition in many parts of the test. Hmm.
Hands down the Fords are built stout. Of course this comes with a weight penalty, but is the most desirable for a long lasting work truck.
If you are that worried about a truck that is a tad quicker than the Fords, maybe you should just buy that instead.
The Torqueshift is a stout and reliable tranny, sorry IMO the truck don't need a 6 speed.
Of all the bad mouthing of the Fords that I have been driving lately, the Torqshift is always the one shining light in the dark. That has got to be the toughest auto I've ever driven and I beat the crap out of a couple of them regularly.
The V10 (properly equiped) vs the 6.4 (stock anyway) is almost a wash. Both seem to pull about the same and the 6.4 isn't putting up mileage #s much better than the V10. With gas being much cheaper than diesel, and upkeep cheaper and easier, it would be hard to justify the diesel if you didn't just want it.
Mike
Mike
