Hazard Lights/E40D?
#31
#32
4way hazards/E4OD?
I took another ride and sure nuff it is about a 250 to 300Rpm difference between the 4ways on/ 4ways off.
Is this normal?
How do I fix this ?
Od light flashing also on shift selector .
Thanks in advance
Any help is appreciated.
...What I lack in knowledge of this,
Is made up with ignorance! Ha Lol!!
Is this normal?
How do I fix this ?
Thanks in advance
#35
No, I haven't done anything yet. Went to parts house , got dielectric grease , started raining as I left store. Busy schedule from today till Sunday after church. Hopefully I can start then. But will ck light between showers soon as I can .
Thanks mark and all of u guys for the input and help. Got a lots goin on, and guess I'm just disgusted .
Thanks again ,
Will post progress.
Gtxx
" Time is NOT on my side" ....lol.
Thanks again ,
Will post progress.
Gtxx
#36
Hi fellas,
Here is my update on 4way flashers/e4od and flashing od light problem.
I am very thankful to all u fellers a am pleased to post that all I did was change the burned out 3rd brake bulb and now everything works perfectly.
The od light stopped flashing, and the rpm's never fluctuated at all when 4ways on or 4ways off , no matter what speed or gear I was in. No Change Period!!!!!
Thanks again fellas
Btw , if that rpm change is normal for your e4od, u might have other issues.
Gtxx
94" f250 XLT 7.3idi E4OD tranny and trailer brake controller.
Nutin fancy, needs a paint job.
Thanks again fellas
Gtxx
#37
2 nd update, E4od flashing od light.
Od flashing light came back, but does not do it all the time. When conditions permit I will check connections and re scan codes.
I sure am glad the flashers have no effect on the engine rpm at all as before. All I did was change the 3rd brake light bulb. That is amazing too me .
thanks again
Gtxx
I didn't see the sun formed or the universe created,
But I see the galaxies at night and the sun rise Every morning.
This too is amazing .
thanks again
Gtxx
#38
Hmmm
Reading through this thread sends me in the right direction. I have a 97 and experience this same issue. My 3rd brake light is out, so I will start by replacing that bulb first. Only thing is that I get no sound (flasher) or indicator (visual blinking) from the flashers when I activate it. The TC does unlock. I also noticed that if I activate the flashers, and then start driving...my ABS light comes on and neither of the blinkers work. Crazy how they designed these things.
#39
Update: well fellers ,after 2mo+ of rain I haven't driven or made any changes. Od light was still flashing until last night. I responded to a family emergency at warp speed . Lo and behold, On my way back I noticed od light was not flashing or lit at all. Ran code this am and got a 66 trans ovr temp +250 f indicated, and a 11 mem passed code. I pressed od button and the light still works.....hmmmmm? I touched nothing!!!!!
Can anyone elaborate. ????
Thx,
Gtxx
Thx,
Gtxx
#41
Last update....
I 've been driving the vehicle (94 F250 7.3 idi pre power stroke) more lately and no E4OD OD light issues, no rpm changes due to 4way flashers activation. after all the aggravation, and former expert advice, all I did was replaced the Psom chip on the speedometer which eliminated the slamming gear changes, replaced the blown 3rd brake light (on cab), cleaned-and replaced the transmission plug and drove the heck out of it . @present 244K mi
...and btw, the individual posted that they thought he was nuts cause he had a similar RPM flasher switch problem , I believe you, lol. And I'm not an engineer.
Thx fellers.
also , it AIN’T normal when you engage your flasher button and your engine revs up 300 rpm and drops back down when you disengage it.
(On any vehicle i have ever operated) 🤷🏽♂️ So
Was this a ford transmission engineering academy rule of thumb thing that no one but 30+ year experienced transmission engineers was taught????????!
Im jus wondering, im always open for technical expertise and experience, no matter where it comes from.
God bless
Thx fellers.
God bless
#42
