460 bolts
460 bolts
What bolts are you looking for exactly? The external bolts for manifolds, covers, etc...
Chris
79 F-150 Lariat: Long-bed, 2wd, 460 (intake, headers, cam, early heads), C-6 (shift kit)
79 Mustang: 460 swap under way, balanced rotating assembly, forged pistons, truck rods, c-8 heads ported, Lunati solid lifter cam, more stuff...
98 Chevy Silverado ext. cab 4x4 (work truck)
95 Lexus SC300 (wife's baby)
Chris
460 bolts
Let's get more specific shall we.
Which ones are you thinking about ?
Head Bolts
Valve cover bolts
Water pump bolts
Fan bolts
Fan clutch bolts
Intake manifold bolts
Exhaust manifold bolts
Carb mounting bolts
Thermostat housing bolts
Power steering bolts
Alternator bolts
I had some time on my hands.
Dennis
[font color =red]Calgary,Alberta,Canada [/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color =green]http://www.clubfte.com/users/mil1ion/Mil1ion.html[/font]
[font color =green]http://community.webshots.com/user/mil1ion[/font]
[font color =green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Head Bolts
Valve cover bolts
Water pump bolts
Fan bolts
Fan clutch bolts
Carb mounting bolts
Alternator bolts
Dennis
460 bolts
I also am putting together an engine with a lot of the original bolts missing. Get yourself a drill and tap chart that lists the diameter of the hole to be drilled for the tap. I got mine at a local machine shop supplier. It's also nice to have to convert drill letter sizes and fractions to decimals. It's hanging on the wall of my garage. They also had a small card that Brown & Sharpe distributes. Then buy a inexpensive set of inside/outside calipers that measure in thousandths. Your local auto parts store might carry them or look in JCWhitneys (where I got mine, $20). For holes to be sized, measure the diameter of the hole with the calipers and then look up the tap drill size up on the chart. There is coarse and fine threads but most all are coarse. Just count the threads per inch if in doubt. For the depth, I am using a piece of wire bent at the end into a small J. I then rake the wire down the threads until I feel the last one, put my thumb flush with the surface and measure the depth with the calipers. Remember to add whatever the plate thickness is plus any washers. For the bolts, you can measure the OD and count the threads per inch. They also make a bolt card that is a plastic card with threaded holes in it to determine bolt sizes. My bolt supplier was out of stock so I'm guessing this is a popular item. Hope this helps.
460 bolts
All these bolts are coarse thread.
Valve covers:
(14)1/4x3/4
Water pump/timing cover:
(6) 5/16 x 4
(5) 5/16 x 1 3/4
(3) 5/16 x 2
(2) 5/16 x 3/4
(1) 5/16 x 2 1/4
Intake:
bolts(10) 3/8 x 1 3/4
studs(6) 3/8 x 2 3/8 with 5/8" threads on each end
Carb:
(4) 5/16 x length varies on carb/spacer combo
Thermostat:
(2) 5/16 x 1
Distribotor:
(1) 5/16 x 3/4
Fuel pump:
(2) 3/8 x 1 1/4
Oil pan:
(20) 1/4 x 3/4
(4) 5/16 x 3/4
Exhaust:
Manifolds (14) 3/8 x 1 1/4
(2) 3/8 x 1 7/8
Headers (16) 3/8 x 1
Exhaust manifold bolts may vary. These measurements are from my truck manifolds used on a 78 460 in an F-150.
As far as the P/S and alternator brackets go, it varies from engine to engine as to which vehicle it was used in. This list should get you started.
