Best set up for a 460?
Hi. I'll give you a rundown of what I am doing to the 460 in my 78 Supercab 2wd. Starting out, the block will be bored .030 over. I'm using stock truck rods with the "football head" rod bolts, ARP rod bolts, Clevite bearings and rings. I'll probably use dish pistons to keep the compression down. Compression should be around 10:1. The heads I am using are D0VE-C castings that have been ported, polished, stainless steel 2.19"int/1.75"exh valves, surfaced, bronze guides, guide plates and roller rockers. The cam I am using is a Lunati solid grind,part #41605, .559"int/.572"exh lift, 237/247 duration @ .050 This should be good for close to 500hp at the flyfheel. Hope this can help a little with your build.
winginit
08-14-2015 09:44 PM
BBpwer
03-30-2015 10:06 PM
BadDogKuzz
03-08-2015 11:24 AM
N.W.Ford
09-21-2014 05:58 PM
