Cold!
http://youtube.com/watch?v=NUxpTZXLcfs
there's a link to a video of my stroker.. when it was a bit warmer.. :0)
on
Originally Posted by MADVAN
My best so far has been -10*f last year in NH.
No plugin. Started right up but was a little stiff/sluggish .
Love the 30wt in winter.
If i remember ford recommends it at 0*f
Bill
Bill
last few days , around 0 (llib knows) ,,15 /40 ...
Truck complains a little ,,, starts ok, doesn't like moving too much,,,(wants to stay home)....
Man, I wish I could get my '95 F350 to start in those temps. I have to plug in if the truck is going to be shut down for more than 4 to 6 hours and hope that the power stays on. Loss of power = No heat = SCREWED! I start having cold, no start problems around 40degrees. I had all new GP's and a new relay installed last winter, however I'm not seeing the voltage drop that I saw all summer.
Sounds like a relay problem.
I didn't start my truck since Sun. night and the high was in the teens today with a sunny sky. Tonight temps even colder.
I don't plug in my truck since I can't. I went out to start it this eve and I let the GPs cycle for the full two minutes.
I almost thought the batteries were dead. I had to crank it over a couple of different instances cycling the key from run to start and then off.
So, tonight I took advantage of my alarm's setting and the truck starts every two hours and runs for 9 minutes. Waste of fuel but keeps the truck able.
