Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-20-2008, 07:06 AM
joe shmoe is starting off with a positive reputation.
Question setting seats 01EB expy
Ok I've tried to do it but seems not to ...How do you save the memory for the seats and peddles...I've tried searchin but came up with other issues ..Any help.Also any other issues I should know about the memory?...........Thnx
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-20-2008, 09:13 AM
P.K. is starting off with a positive reputation.
setting seat memory
move seat,side mirrors,and pedals to desired position,press the set control. the set control light will briefly light up,while light is lite press control 1. repeat the steps for the other seat. activating/deactivating the memory feature on your remote transmitter, ignition switch is in off position,doors and liftgate window closed, the following steps must be done within 30 seconds or you will have to preform these steps over. step 1, turn ignition key on. step2, press the power door unlock control three times. step 3, turn ignition key from on to off. step 4, press the power door unlock control 3 times. step 5, turn the ignition back on, the horn will chirp. step 6, press the power door unlock control 2 times, then press the power lock control once. the horn will chirp twice if the memory feature was deactivated or 3 times (2 short a n one long) if the memory feature was activated. step 7, turn ignition to off, the horn will chirp once to confirm the procedure is complete. I hope this helps, I too have a 2001, I took this out of the owners manual.DO STEPS 1-7 WITHIN 30 SECONDS OR IT WON'T TAKE.
  #3 (permalink)
Old 01-20-2008, 09:15 AM
Thanx,truck I have dosn't hav onwnrs man...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
