1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
HELP Rear Wheels locking up on 05 f250 diesel 4X4
Old 01-19-2008, 11:21 PM
z06vette906's Avatar
z06vette906
z06vette906 is offline
Question HELP Rear Wheels locking up on 05 f250 diesel 4X4
I got some problems and want to know whjat yall think i got a 05 f250 4X4 and the prolem is when u put it in 4X4 when you turn (at a slow speed also really just on fairly sharp turns) the rear wheels just lock up and the front ones just drag them... Any thoughts???? thanks edwin
Old 01-20-2008, 09:13 AM
dougc's Avatar
dougc
dougc is offline
I would guess the problem has to do with your locking diff (if you have one). someone will correct me, but I think the diff has a switch or is electronically controlled and might be locking up too early and too often--maybe it thinks you are losing traction when you turn? If that is the case, you may need a new switch (if there is one). If might also be that you could fix the probelm by changing fluid and cleaing out the gears and housing. But--THIS IS JUST A GUESS.
Old 01-20-2008, 12:06 PM
z06vette906
i was think possibel fluids as well as far as the diff goes i dont think f250 comes witha locking diff in the rear maybe im wrong but thanks for your reply im going to check my fuilds to start with and prob. call ford tomm.
Old 01-20-2008, 12:25 PM
D8chumley's Avatar
D8chumley
D8chumley is offline
Resident smarta$$
Maybe something is binding in the TC when in 4wd? Keep us posted!
Old 01-20-2008, 01:37 PM
dougc's Avatar
dougc
dougc is offline
I'm sorry--I missed the part where you said you had it in 4x4. Does it does this while you are on the street? If so, take it out of 4x4. The 4x4 system is a true 4x4 system, not an all-wheel drive system. Although the binding you are describing is extreme, you will get binding from the system if there is not enough slippage under the wheels.
As for the locking diff comment--you're right, there is no factory locking diff; it might have a limited slip diff that is locking up.
Larry00663
03-15-2016 09:29 PM
psu927
03-02-2016 02:48 PM
deputydog03
15
12-10-2015 07:40 PM
heebeha
03-16-2015 02:20 PM
f250white
01-23-2015 07:10 PM
Quick Reply: HELP Rear Wheels locking up on 05 f250 diesel 4X4
