HELP Rear Wheels locking up on 05 f250 diesel 4X4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-19-2008, 11:21 PM
z06vette906 z06vette906 is offline
z06vette906 is starting off with a positive reputation.
Question HELP Rear Wheels locking up on 05 f250 diesel 4X4
I got some problems and want to know whjat yall think i got a 05 f250 4X4 and the prolem is when u put it in 4X4 when you turn (at a slow speed also really just on fairly sharp turns) the rear wheels just lock up and the front ones just drag them... Any thoughts???? thanks edwin
Old 01-20-2008, 09:13 AM
dougc dougc is offline
dougc is starting off with a positive reputation.
I would guess the problem has to do with your locking diff (if you have one). someone will correct me, but I think the diff has a switch or is electronically controlled and might be locking up too early and too often--maybe it thinks you are losing traction when you turn? If that is the case, you may need a new switch (if there is one). If might also be that you could fix the probelm by changing fluid and cleaing out the gears and housing. But--THIS IS JUST A GUESS.
Old 01-20-2008, 12:06 PM
i was think possibel fluids as well as far as the diff goes i dont think f250 comes witha locking diff in the rear maybe im wrong but thanks for your reply im going to check my fuilds to start with and prob. call ford tomm.
Old 01-20-2008, 12:25 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
Maybe something is binding in the TC when in 4wd? Keep us posted!
Old 01-20-2008, 01:37 PM
I'm sorry--I missed the part where you said you had it in 4x4. Does it does this while you are on the street? If so, take it out of 4x4. The 4x4 system is a true 4x4 system, not an all-wheel drive system. Although the binding you are describing is extreme, you will get binding from the system if there is not enough slippage under the wheels.
As for the locking diff comment--you're right, there is no factory locking diff; it might have a limited slip diff that is locking up.
Auto 4x4 not engaging Larry00663 1999 to 2016 Super Duty 2 03-15-2016 09:29 PM
06 f250 steering problems psu927 1999 to 2016 Super Duty 3 03-02-2016 02:48 PM
2005 F350 4x4 questions? deputydog03 1999 to 2016 Super Duty 15 12-10-2015 07:40 PM
Front Locking hubs Problems engaging 4x4 heebeha 1999 to 2016 Super Duty 10 03-16-2015 02:20 PM
4x4 hubs not auto locking f250white 6.0L Power Stroke Diesel 1 01-23-2015 07:10 PM
Tags
2006, 4x4, diesel, f250, ford, rear, slipping, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
