Grinding noise....?? - Page 6 - Ford Truck Enthusiasts Forums
  #76
Old 05-23-2012, 07:03 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
As you sped up the vacuum pressure changed (normal). The re-occurance of the grinding at that time indicates there is still a leak somewhere in the 4x4 vacuum lines, or a bad IWE internal seal. Have you checked the two (one way air flow) check valves? They are often overlooked when trouble shooting.
97 f150 front end problems Bivika 1997 - 2003 F150 2 09-11-2016 10:08 PM
Drive train Grinding? motomax55 1999 to 2016 Super Duty 4 07-06-2016 12:13 PM
2007 F150 w/ Triton 5.4L wants to stall when it idles down skipper_123 2004 - 2008 F150 7 10-15-2013 07:53 PM
Not good. Serious front end whine/grind. Help! shaferz Excursion - King of SUVs 7 01-28-2012 11:45 PM
Popping and grinding from under the truck Fedds3.0 1997 - 2003 F150 5 04-19-2011 09:41 AM
Tags
04, 4wd, brakes, engaged, engaging, f150, fly, grindingrubbing, horrible, idle, loud, makes, noise, problems, scraping, shift
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
