460 rebuild or short block
Old 08-21-2000, 04:19 PM
cowlady1950's Avatar
cowlady1950
cowlady1950 is offline
Old 04-10-2002, 04:05 PM
KJKozak2's Avatar
KJKozak2
KJKozak2 is offline
Greetings all,
I have a 75 460 in my 78 F150. It runs real good but burns a little oil. The 460 has a lot of miles on it and probably won't last too much longer. I can either rebuild it or get a new short block.
I was quoted $800 for a short block 460 from Checker Auto and I know it'll be a lot more to rebuild the one I have. The only performance mod I would make above stock would be a cam.
If it were you, would you rebuild or get the short block?
Anyone know the quality of engines from this place?
Thanks in advance.
Kevin K.
Old 04-11-2002, 05:02 PM
dvlinnell's Avatar
dvlinnell
dvlinnell is offline
A short block doesnt come with the heads, which is more than likely where your problem is. Your valve stem seals are probly leacking.
Old 04-13-2002, 01:51 AM
TBirdGuy's Avatar
TBirdGuy
TBirdGuy is offline
If you're not gonna go with a performance mod, then just get the short block because then you'll at least have some form of a warranty with it. If you are gonna hop it up a bit, then build it yourself so that you know EXACTLY what you are getting.
TBirdGuy
Old 04-14-2002, 07:09 PM
gray79f250's Avatar
gray79f250
gray79f250 is offline
i say do it yourself you could rebuild for less than $800 including buying a better cam PAW has some very affordable engine kits specialy if you keep it near stock
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: 460 rebuild or short block
