460 conversion - Page 3 - Ford Truck Enthusiasts Forums
460 conversion
  #31
Old 04-18-2001, 05:02 PM
tbolt 460's Avatar
tbolt 460 tbolt 460 is offline
tbolt 460 is starting off with a positive reputation.
460 conversion
haaaay TBIRDGUY
Did the 460 ever come stock with flat top pistons??
  #32
Old 04-18-2001, 05:45 PM
TBirdGuy TBirdGuy is offline
TBirdGuy is starting off with a positive reputation.
460 conversion
I don't think that they ever came with true flat tops. The pistons I pulled out of my motor were flat tops, but they had a rather large valve relief cut into them. When I replaced them, I got a set of hypereutectic flat tops from Keith Black that had only a single valve relief cut into it just large enough for the intake valve. They probably wouldn't work with a high lift cam, but for what I am using they were perfect. Hope that helps.
TBirdGuy
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
  #33
Old 04-19-2001, 02:13 AM
tbolt 460's Avatar
460 conversion
TBIRDGUY
what year 460 was it?The ones you took out just had valve relief,or dished with valve reliefs.I looking for stock flat top with valve relief pistons for a 460
Dave
  #34
Old 04-19-2001, 02:33 AM
tbolt 460's Avatar
460 conversion
do you have your old ones?
  #35
Old 04-19-2001, 08:06 AM
460 conversion
No, threw my old ones away. They were in a 71' 460. They were dished with reliefs. I don't know if there ever were stock flat tops with only a valve relief. You may be able find them for a 429 and just run a 429 instead, but other than that you'd have to get aftermarket pistons if you want true flat tops with just the valve relief.
  #36
Old 04-20-2001, 12:00 AM
mike460's Avatar
mike460 mike460 is offline
mike460 is starting off with a positive reputation.
460 conversion
as for an 87 with a 460, the 250 mounts for a 460 should work, and in 87 you could also get a c6, so you could also use that crossmember(if that is what you are using). but let me know what you find out, cuz i have an 88 f150 that i have been considering the same swap....i just have to make the damn thing meet emissions.
mike
  #37
Old 07-31-2001, 12:22 PM
red73mustang red73mustang is offline
red73mustang is starting off with a positive reputation.
460 conversion
Hi T-Bird, Im planning on doing this 460 stroker conversion for my 73 mustang and would like the stock numbers for the Arias pistons sold by Summit that you mentioned and any other sources for the nessasary parts to complete this Monstor motor. So far the BB Chevy rods required can only be found in that 6.700 lenth in a few places and are a bit pricey ($539.99 a set), still cheaper than a stroker kit though. Thanks, LMK by e-mail if you can
Chet Jones;
e-mail
red73mustang@netzero.net
  #38
Old 07-31-2001, 12:54 PM
fordmanSLO fordmanSLO is offline
fordmanSLO is starting off with a positive reputation.
460 conversion
I would greatly appreciate a copy of that 520 stroker kit info. My email is fordmanslo(No Email Addresses In Posts!) Thanks
  #39
Old 07-31-2001, 04:00 PM
fatherford fatherford is offline
fatherford is starting off with a positive reputation.
460 conversion
[font size="1" color="#FF0000"]LAST EDITED ON 31-Jul-01 AT 05:17 PM (EST)[/font][p][font size="1" color="#FF0000"]LAST EDITED ON 31-Jul-01 AT 05:07 PM (EST)[/font]
On the 87 460 swap, I went to the ford house, bought the brackets for the 460 for a f250, bolted right up, then went and bought a rear sump oil pan. Headmen Headers sells headers that work, and it just bolts right in. Couldnt get any simpler.
You can see the mounts and such on the engine here.
projectbigred.20m.com/pics/block16.jpg
Here are the brackets for the engine in the truck, bolted in.
projectbigred.20m.com/pics/ebay2.jpg
the headers that bolt right up.
projectbigred.20m.com/pics/header.jpg
the oil pan in place(Ford Motorsport kit)
projectbigred.20m.com/pics/block14.jpg
Sorry i would have pics of it in the truck, but i ran out of space on the server. But its a breeze to put in. One thing though. We have the carb sittin on a spacer, and that put it high enough we had to get a oval air cleaner, or it would hit top of the engine bay. And for emissions stuff. We left it off. Just find some inspection station in the booneys, they pass anything.
I think that is all. If you have any more questions or such just email me at FATHERFORD(at)hotmail.com
Oh i forgot, you need to buy a remote oil kit of some sort. There is another part ford motorsport sells that moves it to be perp to the font of the block, but that is messy, and besides remote oil kits look kewl.
  #40
Old 08-02-2001, 10:35 PM
mavman mavman is offline
mavman is starting off with a positive reputation.
460 conversion
I think the lincoln blocks they're referring to are the ol' lincoln 462's...but not sure. they're a whole other beast from what I've heard, nothing like a 460. I have also heard of a 534 (?) lincoln...I think they guy might have been pullin my leg!
  #41
Old 08-11-2001, 12:24 PM
dprasse dprasse is offline
dprasse is starting off with a positive reputation.
460 conversion
Quote:
I've built an 82 460, and 2 88's, and a 69 429, didnt find ANY differenced in the blocks..Thinnk someones been readin too many car craft mags...
Hi ,
several differences ....
The post '79 blocks may have internal clearance problems with a stroker crank. The cylinder bores are close to a 1/2" deeper
towards the crank than pre '79s .
I try to use blocks marked from the Cleveland Foundry ...
the were cast more accurately .
If I'm using the Michigan blocks , I always make sure the lifter bores are centered and the oil pressure sender hole is centered .
If they're not centered , none of the other " major " holes are centered in the castings , either
dP
  #42
Old 03-26-2002, 11:34 PM
mike460's Avatar
460 conversion
  #43
Old 04-13-2002, 10:37 AM
mercade1 mercade1 is offline
mercade1 is starting off with a positive reputation.
460 conversion
Rob, I am interested on the way to increase the 460 to 514, I am putting one in my 78 259 4wd, also does it make any diference where that 460 came from ? right now it seats on a 79 2 wd 250, it seems they had to cut the frame rail on the passanger side to acomodate the exhaust manifold, thanks, Jorge.
  #44
Old 04-14-2002, 06:44 PM
gray79f250 gray79f250 is offline
gray79f250 is starting off with a positive reputation.
460 conversion
for anyone intrested in those transdapt mounts i just happen to have a set for sale on ebay right now and the reserve price is less than half of new just thought id let ya know to save you a few bucks
  #45
Old 04-14-2002, 08:12 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
460 conversion
>Jorge.
This thread is TWO years old.
It's nice to see you were checking archives.
Although those guys might not even be around anymore.
You could have started another instead.
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven!
[/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color =red] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
460 crank sensor help 96-97 camarokid81 1987 - 1996 F150 & Larger F-Series Trucks 13 12-19-2009 07:46 PM
460 Ford vs. Lincoln 64Blubyu Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 14 02-20-2008 09:03 PM
Ford 557 Stroker Kit jamies460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 05-12-2006 07:05 PM
Motorcraft Carb Identification (Specs) tirediron Fuel Injection, Carburetion & Fuel System 1 01-28-2006 01:31 PM
Problems with Fel-Pro MS90618 intake manifold gasket 1977_250_460_C6 Performance & General Engine Building 4 12-02-2004 08:54 PM
Tags
2001, 400, 429, 460, 4x4, conversion, conversions, expedition, f250, f350, ford, header, headers, ranger, tdp9720, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
