Quote:
Originally Posted by dannyfumi
Thanks for thr replies! The smell happens in the actual truck and outside the vehicle as well! Would the EGR valve be the culprit??
Dan
No.
The source of the hydrogen sulfide has to be from one of two sources: Either from an over-cooking battery (outgassing) or from the exhaust.
If from the exhaust, it's usually due to excessive sulfur content in the fuel or is a result of spirited driving that has loaded the converters with fuel beyond their capacity to properly process it. A defective converter is a possibility, however, the other sources should be investigated and eliminated first.
If the source is from the exhaust, the first course of action is to change your place of purchase of your fuel and see if the odor goes away.
Steve
