01-20-2008, 05:19 PM
Hey Mike, Nice to have you here at FTE! Glad you found us and hope you stick around.
The OEM aluminum intake uses the Intake Manifold Runner Control setup (IMRC) so there is more involved if you wind up using one of those.
I am not sure if the newer (plastic) equipped engines manitained all the support systems that would allow for trying to use an old manifold on a newer long block.
To be honest, I am not sure what differences might disallow the use of one intake or the other.
I'd guess the plastic would be more likely to present fewer problems since the IMRC is not involved.
Also, all aluminum intakes used a manual throttle body. I believe there were a few years when the plastic intake manitained the manual throttle body, but all 2005 and newer engines use an electronic throttle body (no throttle cable).
As far as reliability, I've never heard of many problems with either.
I put 170,000 miles on a 2000, and have 121,000 on a 2005.
The gasket leaked at 155,000 on the 2000. But I have never had a problem with just the intake manifold on either.
Hope this helps some and please come back with more questions if you have them.
We'll help best we can!
