Changing fluid in transfer case
'04 manual calls out 2 quarts of Mercon ATF for the transfer case.
I'm no mechanic, but I've never seen a transfer case that didn't have a drain plug and a fill plug.
Getting the fluid out is probably easy. Getting new fluid in may be a real pain without a fluid pump and enough tubing to get up to the fill plug. Auto parts stores usually carry a little hand pump that screws on to oil jugs that costs less than $10 (looks like a big liquid soap dispenser pump) and is well worth it IMO.
Originally Posted by 04 FX4 Lineman
I did my 04 very easy drain it from the bottom plug re fill in the upper plug I bought a small pump that screws onto a 1 qt. bottle it uses mercon ATF and it will start to run out the fill hole at about 2 qts. then put the plug in and u are finished.
Originally Posted by O1COBRA
I need to change the fluid in the transfer case and have never done it. I see that there is a drain and fill plug so im assuming that its pretty easy but am unsure of the fluid needed. Is it regular oil or something special. Any advise would help. Thanks
I changed the fluid in my t-case a while back.
It is a very easy process, this one has a drain plug (not all do).
Drain the fluid, it won't take long.
I keep the gear oil containers b/c they make it easy to do jobs like this.
I was at wal-mart, and saw some oil on sale. They had two quarts of Mobile 1 synthetic Mercron V for $2 a quart. Well, not enough to change the fluid in the tranny, but perfect for the t-case.
I just put the fluid in the gear oil container and put the tip in the fill hole and squeezed. Pretty easy, then did it again, and I was finish.
The old fluid was just a little dark, but didn't look bad.... But it didn't hurt!
Now this is speculation, but if the transfer case layout/function is similar to a Jeep system, the T-case is working all the time, because the rear driveline comes out of it. So, whether or not you use your 4WD, the fluid will need changing. I used synthetic ATF + an additive (MT-10) in mine and changed it about every 15K. I did this because the first time I changed it the oil was brown. After changing to the special mix, the fluid still looked good after 15K and I never had any trouble with that T-case.
Hey guys. I changed the fluid today and used penzoil mercon V. After doing it I took a look at the manual and it mentioned that mercon and mercon V are not interchangable. It said on the bottle that it was ok to use in current ford trannies but now im starting to worry. I know that some of you said that you used mercon V. Im I ok here or should I be making another run the the store for mercon?
