Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-19-2008, 03:00 PM
capted2 is starting off with a positive reputation.
New BII owner... need help
I have recently acquired a 1985 BII. It has 234000 miles on it and has been sitting for 5-6 years without running due to an inoperative fuel pump. I have replaced the pump, changed the oil and installed a new battery. It will now start but will not stay running without pumping the throttle. I have a salvaged Motorcraft 2150 A carb that I have no history on. My question(s): am I correct to think the carb is most likely the problem?, and if so should I re-build the salvage carb before trying it?
Any hints or suggestions will be most welcommed. I live in the southwest desert and hope to turn this little buggy into an off-road explorer.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-19-2008, 03:24 PM
Help I M Stuck is starting off with a positive reputation.
if the fuel is pumping good to the front of the carb then I would think something would be wrong with the carb. Maybe a piece of sludge/rust stuck in it. You did empty out the old fuel and put new stuff in?
__________________
-Jeff
86 Bronco II 4inch suspesnion lift, 3inch body, 35x12.50x15 BFT AT/s and 4:10gears.
05 F250 Superduty Diesel--tows the BII to the trails
  #3 (permalink)
Old 02-08-2008, 08:49 AM
turret_plug is starting off with a positive reputation.
agreed.... but hell, a carb is pretty easy to drop on.... give it a whack.... the skin on your knuckles grows back fast, and by the way, in my experience a MC 2150 hardly ever needs a rebuild and check your vacuum lines from the manifold and from the distributor
__________________
1980 F-100 Stepside... 302, Edelbrock performer series Carb, Intake and Cam...Flowtech headers, and Flowtech dual turbo mufflers
2008 PT Cruiser, stock...... for the time being!!!
  #4 (permalink)
Old 02-08-2008, 12:13 PM
rebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to behold
Diaphragm is probably bad, usually can be swapped in without removing the carb on most vehicles, don't know about your vehicle since it has been a few years since I owned a 1984.
__________________
The Year 2008 Anno Domini -
May it bring a great year of Revelations to you.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
