2002 Ford Excursion 7.3L Oil / Diesel Leak - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-19-2008, 02:57 PM
brucebecwar1 brucebecwar1 is offline
brucebecwar1 is starting off with a positive reputation.
Question 2002 Ford Excursion 7.3L Oil / Diesel Leak
I have a 2002 7.3L Diesel Excursion. It has an oil leak down the back of the engine. It appears to be diesel fuel and not oil. It is leaking out on the passenger side between the engine block and iol pan. It really got the tranny cover all full of oil and thought it was the tranny. But, had the tranny shop look at it and they said No.
Another shop thought it might be the seals between the blower and the blower base unit. Not sure what to think - any thougts?
Old 01-19-2008, 03:02 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Welcome to FTE. Start by looking in the valley of the motor (between the valve covers) to see if there is oil there. There's a good chance you have a bad o-ring that needs to be replaced.
If you find oil in the valley, clean it up the best you can and then look for where the oil is coming out. We can tell you which o-ring you need and how to change it when you tell us where the oil is coming from.
In the mean time, keep some extra oil with you, and keep the engine topped off. Low oil can cause hard/no starts and poor performance.
Old 01-19-2008, 03:07 PM
PETE'S_6.0PSD PETE'S_6.0PSD is offline
PETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to all
well you going to have to investigate a little
first off, get some Simple Green, spray on the engine hose it of and let it dry
than grab the flashlight and check where the top of the motor gets wet,
most likely itd in the back of the fuelbowl, the drainvalve O-rings are leaking. this is most common problem caused by ULSD. and this will drip out of trans inspection cover and by the starter on the side of the block.
if its oil it might be your turbo pedestal, and oil pump lines o-rings
but since you said fuel than drain valve,
look here for replacement information :
http://www.ford-trucks.com/forums/31...king-fuel.html
and here for more
http://www.7point3.com/mods.aspx
and more
http://guzzle.rbmicro.com/index.html
good luck , and let us know if you need more help ...
Welcome to FTE
wfmcbride wfmcbride is offline
wfmcbride is starting off with a positive reputation.
Sounds like the "o" rings on the yellow valve that drains the fuel filter housing, it's a common problem and an easy fix, there is a steel tube attached to the frame on the passenger side that the fuel drains through, it's hard to spot, you'll need a light to find it, if that's where you see fuel on the ground, the "o" rings are the problem. Many of our sponsor's carry a kit with instructions.
Old 01-19-2008, 03:18 PM
Thanks, I will check that. It is leaking pretty good under the car after I turn it off. It will make a little puddle. My oil level has not changed and it should for the amount of fuel/oil that has leaked in the garage and the on the driveway.
Your point about the mess around the trany cover and all over the start is correct. It covers the starter and is on the block.
I will check and get back.
Thanks.
Distraction from a demonic diesel. Tugly 1999 - 2003 7.3L Power Stroke Diesel 10 11-03-2014 06:41 AM
Diesel shop recommendation in Clinton/Waldorf Md aero993 1999 - 2003 7.3L Power Stroke Diesel 10 01-31-2014 04:10 PM
02' Excursion 7.3L Oil Leak in manifold valley rbraxton17 1999 to 2016 Super Duty 6 08-04-2008 01:54 PM
Different fuel filters for 2002 F350 SD 7.3L PSD and 2001 Excursion 7.3L PSD? kabcpapc 1999 - 2003 7.3L Power Stroke Diesel 3 12-04-2004 10:14 PM
Rear Main Seal on a 7.3? Breaks my heart. canuck999 1999 - 2003 7.3L Power Stroke Diesel 17 06-15-2004 08:38 PM
Tags
2002, 73, 73l, diesel, engine, excursion, f350, ford, leak, leaking, location, oil, passenger, powerstroke, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
